Frozen fill plug...
Old Feb 21, 2012 | 09:12 PM
merlinford's Avatar
merlinford
Frozen fill plug...
I've been trying to remove the fill plug on my rear differential over the past few days with no luck. I'm to the point now where I'm afraid I'm close to stripping out the inside of the plug. I've done several searches and tried all the tips...soaking with PB blaster, tapping, heating. Anything else I should try before I drill it out? Picked up this 94 F-250 used, looks like the plug has never been removed.
Old Feb 21, 2012 | 09:23 PM
DBGrif91's Avatar
DBGrif91
Here you go. The thread talks about bolts specifically, but I'm sure this will work for your problem too. My only other piece of advice is that you should use the lowest heat you can to get this to work- the danger of setting the gear oil ablaze is ever present.
https://www.ford-trucks.com/forums/1...ted-bolts.html
Old Feb 21, 2012 | 11:32 PM
Midnite1987's Avatar
Midnite1987
I had to use an oxy-acetylene torch to heat the bugger up I get mine out
Old Feb 22, 2012 | 08:53 PM
merlinford's Avatar
merlinford
Thx guys...I'll give the hot wax technique a shot.
Old Feb 22, 2012 | 09:07 PM
DBGrif91's Avatar
DBGrif91
I don't know if you read all the way thru the thread or not, but just in case you didn't, I want to clarify that we used the wax from a toilet gasket when we removed those broken bolts.
I imagine that a candle will work as well. It may even be easier, if you get a long candle, because then you don't have to pull it apart.
Old Feb 22, 2012 | 10:02 PM
Blue Rebel's Avatar
Blue Rebel
^^^^ I use candle wax at work all the time to loosen up stuck tie rod ends on semi trucks. Works suprisingly good.
Old Feb 24, 2012 | 06:55 PM
merlinford's Avatar
merlinford
Yeah, I was planning on using a candle
Captain D
Dec 14, 2007 08:33 PM
doubleagle
Apr 5, 2006 09:52 AM
1978Supercab
Feb 13, 2006 03:36 PM
fjlee
Sep 25, 2005 12:59 AM
mantta
Jan 20, 2003 04:51 PM
