93 f-150 motor swap (different firing order)
The 93 injectors are batch fired , they fire 4 injectors at the same time , then fire the other 4 , if you want to go to sefi where they fire each cylinder at the same time as the firing order , then you need the computer , wiring harness from the 95 , and the mass air meter to switch from speed density to a mass air system
ok so do i need to use the 93 wiring harness or will the 95 harness work? and i need to use the 95 firing order. from other stuff i've read the 95 appears to an SD not MAF, also the 95 had a manual trans the 93 has an E4OD if that makes a difference. i have to use the 93 computer because of the auto trans.
Make sure you have the plug wires properly routed/separated from each other. Cross-fire is very common. Here is some great info from Steve83: Spark Plug Wire Routing | SuperMotors.net
351Cleveland C4
03-15-2017 10:26 PM
82ford302
06-19-2009 04:31 PM
AaronBett
12-12-2003 03:39 AM
Da Mother Ship
12-08-2003 07:50 PM
