stuck fill plug
Old Apr 4, 2006 | 03:41 PM
doubleagle's Avatar
doubleagle
stuck fill plug
Can someone give me some ideas on how to loosen a forever tight fill plug on my Bronco?!? It's a 1990 fullsize with the Ford 8.8, and the plug is not budging. I don't want to strip out the square hole, and I have already sprayed on gobs of penetrating lube. Please help....
Old Apr 5, 2006 | 09:52 AM
jim henderson's Avatar
jim henderson
some ideas...
You might put a propane torch to the area and heat it up a bit. Doesn't have to be red hot, just warm to hot. Try to remove the plug then. If it still doesn't budge you might try to melt some candle wax into the plug threads while it is hot.
If that doesn't work, you might go the opposite direction and use freeze spray on the plug.
Whatever you do, use a good snug fitting square drive and keept the ratchet handle close to the plug, ie try not to use long extentions since they tend to move the torque off center.
If all else fails, you might try an impact wrench. I might try one of those hammer type impact wrenches first because I am nervous. But in reality, my hammer impact wrench never did work for me. My next step would be to use an adjustable torque impact wrench and start low to just kind of tap the plug out.
Good Luck,
Jim Henderson
bigcountry1009
Mar 26, 2015 03:02 PM
X1Lightning
Mar 21, 2015 10:22 AM
05victorylly
Mar 21, 2012 04:33 AM
mikren
1997 - 2003 F150
Sep 15, 2009 08:09 AM
PNWF-350
Oct 18, 2003 07:54 PM
