Rear End Question
Old Feb 21, 2012 | 04:10 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
Rear End Question
is it normal for these rear ends to break traction easily on wet pavement?
i have noticed that unless i baby my throttle of the line i will be spinning the tires.
i really have to be careful when making turns and getting on the throttle from sitting at a stop light. when turning it is always the inside tire that breaks loose.
i have the full-floating sterling 10.25 limited slip.
thanks for any info.
Old Feb 21, 2012 | 04:22 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Talking '92 1/2 - '94 IDI ip fuel economy killer screw
did you adjust your torque screw on the ip? if so,sounds like you could stand readjusting it,so she's not dumping in so much fuel all at once.the fuel economy will suffer greatly setup like that.what you want is to start out with the least amount of fuel possible of course for economy,but you don't need to go so drastic, to keep some off the line performance.just enough so your not dumping fuel at all once making for such a touchy throttle that the tires want to slip wasting energy from the fuel,not moving your forward.
on a side note,sounds like you have your E40D setup good and the converter is still in good shape.
Torque Screw Adjustment - YouTube
Old Feb 21, 2012 | 05:15 PM
'94IDITurbo7.3
nope. have not touched the torque screw or the fuel screw under the triangle cover on the IP.
nor have i done anything with my tranny or tps. lately though it does seem to get up to speed a little easier without so much throttle input.
Old Feb 21, 2012 | 05:26 PM
FORDF250HDXLT
it just runs good without any effort.
well,your going to be making several idi owners a bit envious lol.
Old Feb 21, 2012 | 05:36 PM
'94IDITurbo7.3
my truck is just weird like that. the other day i got out of work, and drive off. once it warmed up the throttle response was awsome, tranny was working good, and the truck had some giddy up to it. i have done NOTHING to it.
Old Feb 21, 2012 | 08:20 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I think that's a case of ****ty tires
Old Feb 21, 2012 | 08:34 PM
'94IDITurbo7.3
practically brand new firestone transforce A/T's.
Old Feb 21, 2012 | 08:38 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Auto, 4.10s, LS.. thats why. lwb doesnt help it much either.
Old Feb 21, 2012 | 08:40 PM
IDIDieselJohn
Well then, you have a well tuned IDI
I hope my van can burn 'em with it's new injectors
Old Feb 21, 2012 | 08:42 PM
'94IDITurbo7.3
oh man, if i really wanted to i could drift around corners so easily. might not be pretty but could be done..............................wet pavement of course.
on a more serious note, the breaking traction sounds normal?
Old Feb 21, 2012 | 09:11 PM
whiteboyslo's Avatar
whiteboyslo
The EXACT same thing happened to me about a week ago. I was turning left at a light from a dead stop, went to shift to 3rd, and the next thing I know I'm sideways. It was an ***-pucker moment for sure. I chalked mine up to a few things:
1. The truck is still new to me (as is diesel and all that low-end torque), so I'm still getting used to how much throttle to give it in different conditions.
2. The tires have seen better days. Saving the pennies now to get a new set soon.
3. There was a light rain that day.
4. No limited slip.
But yeah, I would say it's all normal. There's no weight back there, and E-rated tires aren't really known for exceptional grip.
Mike
Old Feb 21, 2012 | 09:14 PM
'94IDITurbo7.3
i actually have about 450lbs of concrete right over the axle right now. i put it in for the snow.
Old Feb 22, 2012 | 03:27 PM
Marianna2003's Avatar
Marianna2003
Stack your concrete against the tailgate and secure it there. Your 450#s will transfer somewhere in the in the 500-600# range. Mayu as well take advantage of all the weight transfer you can.
Old Feb 23, 2012 | 04:14 AM
Jim Allen's Avatar
Jim Allen
If you think it's bad in wet weather, try it on ice! You'll have the same problem in reverse trying to stop hard and locking the rear tires.
Yeah, the weight is a good idea. I used to put 500# of tractor weights in the truck bed for winter, just behind the axle, to aid with traction. Ditto when I pull loaded grain wagons (which don't have an tongue weight because they are four-wheeled).
I also suggest running less tire pressure when unloaded to increase the tire footprint. If you have the max sidewall pressure, that's for a max tire load and your tread footprint is about the size of a silver dollar with the truck empty. With only about 1/3 of the total weight of the (empty) truck on the rear tires, it' like you are riding on bike tires. I run as little as 28 psi but generally around 35 psi on my rear (285/70R16 radials) to allow for a light load. If I need to carry a full load, I air all the way up. If you have smaller tires, you will need more pressure than bigger ones (remember it 's the volume of air in the tire that carries the load and a bigger tire has more internal volume so needs less pressure to carry the same amount of air (by volume) as the tire with less internal volume)
Old Feb 23, 2012 | 09:57 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
PLEASE ENSURE you restrain them from sliding/flying forward in case of quick (or instant) stops ...
A friend of a friend was killed by the weights he carried in his truck.
-Enjoy
fh : )_~
