Need help with boost problem ?
Old Feb 20, 2012 | 09:25 PM
Mike/f250's Avatar
Mike/f250
I just put gauges in my truck and can't get my boost to go over 5psi . Any ideas what I need to check ? Thanks
Old Feb 20, 2012 | 09:36 PM
BigAlsPSD's Avatar
BigAlsPSD
I assume this is on your 2000 7.3?
What type of gauges? Where are you getting your signal?
Better luck where I'm sure John will move this... in the www.ford-trucks.com/forums/forum31/
If all is well with installation and you actually have boost leaks, check intercooler boots for tears/tightness, as well as leaking up pipes.
Old Feb 20, 2012 | 09:47 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old Feb 20, 2012 | 09:53 PM
woodnthings's Avatar
woodnthings
Are you checking it while driving? Many try it in the driveway which doesn't work. To get boost you have to load the engine.
Old Feb 21, 2012 | 06:24 AM
Tugly's Avatar
Tugly
And by loading, that's not dashing to the store to pick up groceries. A lonely road and an anvil on the throttle is where I check the boost behavior. I usually get no higher than 25 but I've seen it peak at 28. I have a big intake (see my signature links), but stock exhaust for about 2 more weeks.
Old Feb 21, 2012 | 06:52 AM
Mike/f250's Avatar
Mike/f250
Yea its on my 2000 f250 . And my Boost gauge is the pressure type from auto meter . I taped in to my intake mainfold right above the (AIH) air intake heater.
Old Feb 21, 2012 | 07:01 AM
Mike/f250's Avatar
Mike/f250
Ken. Yea I checked y I was driving . I put it to the floor until I got up to 90Mph and boost only went up to 5 psi
Old Feb 21, 2012 | 11:53 AM
Tugly's Avatar
Tugly
Eeewww.... Blowin' coal.
I don't remember where, but there is a video on this forum showing how to test turbo leaks. Take the intake filter tube off and put a 3" pipe with a cap on it and an air fitting. Inject no more than about 10-15 PSI in there (if it goes that high) and spray soapy water on all boots and turbo output fittings. You'll likely find a big honkin' leak or one tired turbo. Exessive exhaust backpressure can cause this as well, but your EGTs would really jump.
Old Feb 21, 2012 | 12:28 PM
CSIPSD's Avatar
CSIPSD
If the truck is not blowing black, then I would bet you kinked the line when installing it, or overtightened the ferrels and crimpped the line.
Truck would run like crap if it only makes 5psi.
Old Feb 21, 2012 | 05:09 PM
Mike/f250's Avatar
Mike/f250
It only blows a little black smoke and my truck runs like it doesnt have much power .
Old Feb 21, 2012 | 06:14 PM
Tailgate77478's Avatar
Tailgate77478
Then, as stated, you likely have a tear or hole in an IC boot, and/or leaking up pipes. Or both. Based on the age of your truck, it wouldn't be a surprise to have leaking up pipes.
Old Feb 21, 2012 | 06:26 PM
BigAlsPSD's Avatar
BigAlsPSD
Do you hear the turbo? Is your EBPV(Exhaust Back Pressure Valve) kicking in? Any oil in the tail pipe? Have you removed the intake off of the turbo and inspected it for free movement and play in the shaft, side to side is ok as long as it doesn't strike the housing, you don't want any in and out.
Old Feb 21, 2012 | 09:18 PM
PEI's Avatar
PEI
Unhook the red hose going to the wastegate as a test.
That was one of my issues besides leaking intercooler boots..
https://www.ford-trucks.com/forums/1...si-at-wot.html
I stepped on it the other day and got about 27 PSI and the truck defueled.
Plan on hooking the wastegate back up soon, got to take it off first and adjust it.
Truck has a LOT of power now after disabling the wastegate.
Hows the truck working in general? Possible the UVCH connectors are working loose?
Old Feb 24, 2012 | 10:49 PM
Mike/f250's Avatar
Mike/f250
got my new inter cooler boots today and got an (AIH) delete plug,and FRx kit putting it all in , in the morning . thanks everyone
Old Feb 25, 2012 | 01:03 AM
cj45lc's Avatar
cj45lc
Don't forget to check the boots that connect the Y-pipe to the plenums
lakewood
13
Jan 17, 2020 04:14 PM
ved0303
Apr 30, 2015 09:27 PM
smoky_diesel
20
Feb 8, 2008 06:35 PM
c00nhunterjoe
45
Jan 7, 2008 10:29 PM
tneyman
Mar 30, 2007 07:37 AM
