EBP sensor
Old Feb 20, 2012 | 09:09 PM
jerkypants's Avatar
jerkypants
EBP sensor
Hi again
Where is the EBP sensor on an 05?
Also what is the sensor on the passenger side valve cover towards the front?
Thanks
Old Feb 20, 2012 | 09:34 PM
zhilton's Avatar
zhilton
Should be behind the air filter minder...on a steel tube that almost looks like a dipstick tube.
ICP
Old Feb 21, 2012 | 06:45 AM
DevilDocTater's Avatar
DevilDocTater
Master of Disaster
EBP depends on year...on my 2004 it is just right of the thermostat
Old Feb 21, 2012 | 07:07 AM
zhilton's Avatar
zhilton
Arrow #3 in the bottom half photo...but this is an '03-'04 engine.
Right, but he said he's got an '05...thus they moved it.
Old Feb 21, 2012 | 07:09 AM
DevilDocTater
Master of Disaster
My bust, didnt see it on my phone....lol
Old Feb 21, 2012 | 09:06 AM
jerkypants's Avatar
jerkypants
Thanks guys.
Someone told me the ipc was behind the turbo, on the 05.
If thats the ipc valve towards the front end of the passenger side valve cover mine doesnt have a screen on it.
One last question; what does ebp stand for and what does the sensor do?
Old Feb 21, 2012 | 09:15 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
EBP is exhaust back pressure, the PCM uses info from it to decide how to control the EGR valve and the VGT actuator on the turbo
Old Feb 21, 2012 | 09:43 AM
jerkypants's Avatar
jerkypants
K, thanks
My bad it is the IPR that has the screen in it.
Old Feb 21, 2012 | 08:34 PM
zhilton's Avatar
zhilton
And it is under the turbo on all years. The ICP is the one that moved from under the turbo (03/04) to the passenger side (odd numbers) of the engine with the '05 engines.
Old Feb 21, 2012 | 09:47 PM
critterf1's Avatar
critterf1
Wish they would've also moved the IPR while they were in the "moving" mood.
Old Feb 22, 2012 | 05:14 AM
npccpartsman's Avatar
npccpartsman
The ICP sensor was moved to the valve cover on the 04 and up ENGINES but not all 04 trucks, specifically those made before 9/29/03.
Sous
30
Oct 12, 2015 02:04 PM
pickle40
Feb 21, 2015 02:46 AM
B_Allen
Apr 11, 2013 07:46 PM
Texas Chain Ring
35
Feb 16, 2013 07:44 AM
murphym84
Dec 5, 2010 05:55 PM
