Sponsored by: Real Truck
y pipe confusion ?
Old Feb 19, 2012 | 08:28 PM
Renagade800's Avatar
Renagade800
y pipe confusion ?
I have a 2006" f 350 5.4 supercrew Considering new exhaust system and need feed back on this thought .Instead of replacing factory y pipe with an aftermarket one why not just use magnaflow 2 in 2 out with cross over in muffler itself ? And cut out y pipe all together . Considering the cost of the y pipe and installation of it , woudnt it be cheaper to install a second pipe from where y pipe would have been to the new muffler.What would be the diffrence between the two options in performance ? More interested in the performance than the cost .
Old Feb 19, 2012 | 08:34 PM
kas83's Avatar
kas83
2 cats can be pretty pricey. Don't think you'd notice a performance gain with a full dual setup over a single unless you plan on forced induction and lots of rpm require the added flow.
Old Feb 19, 2012 | 08:41 PM
Renagade800
dont want to touch the cats , arent they in front of y pipe anyway /
Old Feb 19, 2012 | 08:44 PM
kas83's Avatar
kas83
On your 06, maybe. Sorry, was thinking about the horrible pipe on the 99-04, esp the pinched 01-04.
Old Feb 19, 2012 | 09:00 PM
Renagade800
qeustion still is , aftermarket y pipe with single in and 2 out , or y pipe delete with 2 in 2 out ? both situations will be using a magnaflow muffler and the 2 in 2 out has cross over in muffler .
Old Feb 19, 2012 | 09:39 PM
dkf's Avatar
dkf
The 99'-04' Super Dutys are what most of the replacements (like from SPD) are made for. The 00'-04' had the worst y-pipe. The y-pipe on the 05'up trucks were quite a bit better however there is usually room for improvement. The 5.4l and 6.8l super dutys were not exactly really popular for aftermarket parts as a lot of the companies ignored them, especially the 5.4l SDs.
Old Feb 19, 2012 | 09:58 PM
Renagade800
indeed , finding after market perfomance bolt ons for the 5.4 frustating. After the exhaust will be the air induction , I've been told that changing this won't make much of a difference at all . Im open to any suggestions though . Maybe a 5 star tune too .
Stinkweed14
6.4L Power Stroke Diesel
Feb 6, 2012 01:04 PM
nuthinbutfords
Modular V10 (6.8l)
Jul 19, 2010 12:55 PM
ozzy460
Feb 11, 2008 08:55 AM
ghunt
General Automotive Discussion
Jan 15, 2008 09:20 AM
ke5adb
Oct 4, 2004 02:44 AM
