6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Straight pipe
Old Feb 1, 2012 | 03:54 PM
Stinkweed14's Avatar
Stinkweed14
Straight pipe
What is it and how do I put it in
Old Feb 1, 2012 | 05:24 PM
smotrs's Avatar
smotrs
A straight pipe is a pipe that replaces the DPF/CAT pipe currently on your vehicle. Plenty of information on the forums explaining how to remove the exhaust system and replace with a delete pipe.
Also, you MUST have a tuner of some sort or your vehicle will go into limp mode if you install a straight pipe or delete pipe.
Old Feb 1, 2012 | 10:35 PM
RM2738's Avatar
RM2738
It's exactly what it says. Straight pipe. No emissions components. DPF, DOC, Muffler. Nothing but pipe.
Old Feb 2, 2012 | 08:34 PM
Stinkweed14
What goes in to taking everything off
Old Feb 2, 2012 | 08:38 PM
RM2738's Avatar
RM2738
DPF & DOC requires the disconnection of 4-5 sensors, a few bolts and removal from the exhaust hangers along with a DPF delete capable tuner. The muffler is welded in so best bet is to buy a new system. Either DPF back, downpipe back or turbo back.
Old Feb 3, 2012 | 09:45 AM
smotrs's Avatar
smotrs
The Downpipe back is probably your easiest.
Old Feb 5, 2012 | 09:14 PM
pmoney1983's Avatar
pmoney1983
Is this statement 6.4L specific?
Old Feb 5, 2012 | 09:21 PM
pmoney1983's Avatar
pmoney1983
I have never heard of it being a "must" to have a tuner for a straight pipe exhaust system to work correctly.
Old Feb 5, 2012 | 09:24 PM
pmoney1983's Avatar
pmoney1983
Also, what is this limp mode that you speak of? I am interested in this. Thanks.
Old Feb 5, 2012 | 09:25 PM
RM2738's Avatar
RM2738
No. Most first generation EPA approved diesels use DPF technology. The 6.7 uses DPF but adds another component to help with the breakdown of exhaust gasses (DEF). Because the process involves the vehicles PCM, it requires a tuner to modify that process.
A gas vehicle can be "straight piped" by removing tha catalytic converter and muffler.
Old Feb 5, 2012 | 09:33 PM
RM2738's Avatar
RM2738
"Limp Home Mode" is just that. Your vehicle goes to a very limited power level to allow you to either get home or at least drive to a safe stopping point in an attempt to prevent major damage or more damage than has already occurred.
Old Feb 6, 2012 | 01:04 PM
smotrs's Avatar
smotrs
Depends on the year of the vehicle. Pre 2008 Ford trucks did not have a DPF so they could just have a straight pipe put in place of the CAT pipe going out toward the rear. Ford truck model years 2008 to 2010 have the DPF in place to capture the soot expelled on the exhaust stroke. It is burned out by injecting diesel on the exhaust stroke to clean the DPF during the regen cycle.
Ford truck model years 2011 and newer also have a DEF feature as RM2738 mentioned which is used instead of diesel to help burn out thee soot in a DPF during the regen cycle.
Pre DPF trucks did not require a tuner to go to a straight pipe as the computer did not control the emissions components on the exhaust system. When they introduced the DPF they also included special programming to activate and deactivate the regen cycle when it detected that it needed to be cleaned.
If you were to straight pipe a 2008 model year truck or newer, your truck would go into constant regen cycle and eventually limp mode without the necessary programming that a tuner performs.
I think RM2738 covered this nicely.
nuthinbutfords
Modular V10 (6.8l)
Jul 19, 2010 12:55 PM
ozzy460
Feb 11, 2008 08:55 AM
ghunt
General Automotive Discussion
Jan 15, 2008 09:20 AM
ke5adb
Oct 4, 2004 02:44 AM
TRIMMAN98
May 7, 2002 11:00 AM
