rear diff fluid
Old Feb 19, 2012 | 07:12 AM
7.3bo-ti-etr's Avatar
7.3bo-ti-etr
rear diff fluid
what weight is our rear differential fluid. It's on a 2wd also how much is needed.
Old Feb 19, 2012 | 07:17 AM
cj45lc's Avatar
cj45lc
75-140 SYN
get 4 qts it takes a little over 3
if you have a limited slip you will need 4-8 ounces of the friction modifier
Old Feb 19, 2012 | 07:28 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
75W140 fully synthetic (I use Royal Purple) and a little under 4 quarts
Opened on 1/14/2012 - found using the forum search feature:
https://www.ford-trucks.com/forums/1...end-fluid.html
Opened on 12/14/2011 - found using the forum search feature:
https://www.ford-trucks.com/forums/1...iff-fluid.html
Opened on 8/13/2011 - found using the forum search feature:
My point is that 99% of the questions any one will ask have probably been answered already. The 3 links above were the most obviously related to your query.... out of 17 pages of results, with 15 lines per page - that's over 250 other threads that had the words "rear diff fluid" in them.
I'm not trying to bash you and only you, and don't want to turn you away from asking questions, but if you do a little research first, you wouldn't be waiting for the answer, you'd have found in less than 5 minutes and been on your way to getting another project completed.
Old Feb 19, 2012 | 07:32 AM
papadelogan
Originally Posted by cj45lc
75-140 SYN
I'd have to disagree on the "need" for friction modifier when running synthetic. I run Royal Purple fully synthetic 75w140 for almost 100,000 miles with no FM added, and a fully functional posi.
If running "dino" gear oil, you will need the FM; if running fully synthetic, then you shouldn't need the FM. If you run Full Syn and feel binding in turns, park on a downhill slope, open the fill plug on the rear diff, and add just 1oz. of the FM. Put the plug back in and go for a drive. You don't want too much FM in there, since that will neutralize the effectiveness of the posi - i.e. too much slipping. You want just enough not to bind in corners, but enough to let the posi work.
Old Feb 19, 2012 | 07:34 AM
7.3bo-ti-etr
I do use the search a lot but I'm in my patrol car and am driving just figured I'd ask really quick instead of driving and searching at the same time. Plan on changing this week. So thanks for the quick responses.
Old Feb 19, 2012 | 08:35 AM
cj45lc's Avatar
cj45lc
I hear you bud, it seems most of the syn fluid has the FM all ready added & it has too much FM from the start.
When I changed mine I got the syn fluid with no FM so that I could add just enough to take the binding out, like you said too much FM just makes for a one wheel wonder. IIRC I had to use about 3 oz of the FM
akblackfoot
Jul 10, 2017 07:53 PM
Deluxe06
31
Dec 17, 2011 08:13 PM
01raptor
Jul 1, 2011 09:19 AM
myred
Nov 12, 2010 10:51 AM
outrunm
Jan 21, 2004 06:53 PM
