I ended up using Amsoil and a bottle of their friction modifier. It was close to the same price as everything else and the local dealer is close to me. He had everything in stock that I needed.
I've tested two different brands in my F-250. Royal Purple and Schaeffer's 75W-140. Wasn't very happy with the UOA reports on the Royal Purple - the viscosity sheared down and the iron wear was much higher than compared to the Schaeffer's UOA. Most of the miles were towing.
Thanks Guys, Hey Rich thanks for posting those UAs good info. Just for giggles lets keep this going post up what Gear Lube you put in your differential when you did a lube change.
I tend to use a lot of the Mobil 1 products, Mobil 1 is in the rear, but Front has Motive Gear because it was all I could find of quality locally at the time.
