DTC p0401 question
Old Feb 18, 2012 | 08:59 PM
jl4407's Avatar
jl4407
DTC p0401 question
I just did a oil cooler and a egr delete, I am throwing a p0401 code now. No check engine light but my insight is pulling the code. Is this due to my egr delete??
Old Feb 18, 2012 | 10:08 PM
bismic's Avatar
bismic
yes - most likely
Old Feb 22, 2012 | 10:56 PM
jl4407's Avatar
jl4407
Does my egr valve still function with my egr delete, it is still plugged in and installed in the truck, I'm just trying to figure out this dtc code. Would this cause a slight studer in the motor when it is cold
Old Feb 22, 2012 | 11:26 PM
steelhead2's Avatar
steelhead2
Its sensing low egr flow. I left mine unplugged to see if id get the same code before i went on with an egr delete, and i got the same code .Youll probably need a tuner to clear that code. As far as the studder i suppose its possible. Someone will chime in soon and be able to answer with a little more detail. Hows your boost?.And yes, the vAlve still functions, but the ebp sensor, and the intake air temp sensor know theres no egr flow. Cheezit explained it awhile back, maybe he'll chime in and give you a little better explanation.
Old Feb 23, 2012 | 12:34 AM
Unrealo4's Avatar
Unrealo4
The studder sounds alot like stiction. Try using rotella t6 5w 40 full syn oil on your next oil change.
ben158
Nov 20, 2014 11:58 AM
davenpt
2004 - 2008 F150
21
Jul 7, 2014 01:33 PM
mblanken881
Mar 15, 2012 02:15 PM
