4x4 doesn't engage...Help please!
Old Feb 17, 2012 | 03:48 PM
96max2fast's Avatar
96max2fast
So, I changed the shift motor on my 97 Expedition XLT and now it engages and spins the rod but the wheels don't spin (while on the lift). Seems like it's not spinning what it is supposed to on the front differential. Does anyone know if this means I need a new front differential or is there something else that could be preventing the wheels from spinning?
Old Feb 17, 2012 | 08:06 PM
alloro's Avatar
alloro
Have you tested the vacuum actuator on the front differential to make sure it's locking in the ring gear?
Old Feb 18, 2012 | 06:41 AM
96max2fast's Avatar
96max2fast
No. how do I test that?
Old Feb 18, 2012 | 12:48 PM
alloro's Avatar
alloro
Remove the vacuum hose from it and supply the actuator with an alternate source of vacuum. You can either use a manual pump sold at most auto part stores, or you can get a long piece of vacuum hose and attach one end to engine vacuum and the other to the actuator.
Old Feb 18, 2012 | 02:01 PM
96max2fast's Avatar
96max2fast
Tested everything and those actuators work...
Old Feb 18, 2012 | 08:28 PM
alloro's Avatar
alloro
I just want to make sure I'm understanding this correctly. While on the lift you can see the front driveshaft turning but the front wheels do not?
Old Feb 19, 2012 | 05:04 AM
96max2fast's Avatar
96max2fast
Yes... It seems like something internally is not working...
Old Feb 27, 2012 | 08:36 PM
96max2fast's Avatar
96max2fast
Does anyone know where I could find a diagram for this 4x4 system? This is driving me nuts. The 4LO is engaging, although it feels like it is slipping when I try to accelerate... I was told that it is a bad differential but, could it be possible to work only in 4LOW and not 4Hi??? I'm getting desperate and may go to dealer for diagnosis...
Old Feb 27, 2012 | 08:48 PM
alloro's Avatar
alloro
A few posts back I asked you if when on the lift if the front drive shaft is turning but the front wheels are not and you said, "yes." So since the front drive shaft is turning, it is getting powered by the transfer case. Since the wheels are not turning, the loss of power is where the front drive shaft is supposed to turn the front axle...at the front differential. Now unless you're not communicating the symptoms here correctly, your problem lies with the front differential. Hopefully it is just the vacuum actuator and not something internal.
Old Feb 27, 2012 | 08:53 PM
96max2fast's Avatar
96max2fast
Yes, all this is correct. The problem is that 4Low actually worked today (although it slips slightly when I accelerate). When I switch it to 4hi or 4wd, it doesn't work... Why the difference?
Old Feb 27, 2012 | 08:59 PM
96max2fast's Avatar
96max2fast
pmoney1983
Jan 16, 2013 03:57 PM
plumbfishy
Mar 1, 2011 06:01 PM
AllAboutTL
Jan 29, 2010 12:58 AM
KS324
Dec 21, 2008 09:36 PM
1987_f150
Sep 27, 2006 07:01 AM
