VACUUM
Old Mar 1, 2011 | 03:10 PM
plumbfishy's Avatar
plumbfishy
VACUUM
Replaced vacuum pump on my 2001 F350 Deisel. still my vent will only blow out the defrost. No wiper spray. Can't find any vacuum leaks. Any HELP
Old Mar 1, 2011 | 03:51 PM
onelionhunter's Avatar
onelionhunter
ESOF
Do you have electronic shift on teh fly 4x4 controls? If you do, i bet one of the little vacuum hoses on teh wheel hub is broke off.
Old Mar 1, 2011 | 04:33 PM
clintbonnie's Avatar
clintbonnie
If you have esof, disconnect the vacuum hose on top of the vacuum tank(that goes downward towards your hubs) and check for vacuum. if you have vacuum here, plug it, on the vacuum side .. then check for your problem..
Old Mar 1, 2011 | 04:59 PM
PaysonPSD's Avatar
PaysonPSD
Couple pics and a diagram. Does the vac pump run. If not check fuse 28 under dash.
Old Mar 1, 2011 | 06:01 PM
hammer65's Avatar
hammer65
My 2003 with manual heater controls, had a gray hose coming from under the right fender, that had become disconnected. It hooked to a dead end plug on the a/c dryer. I think.
Anyway It needed plugging/ Jim
RIKIL
20
Mar 11, 2013 07:49 PM
1978Crew
Mar 30, 2006 11:12 AM
fordflaresides
Jan 29, 2006 10:15 PM
Fasterhorses
1997 - 2003 F150
Jun 30, 2005 08:46 PM
horsepuller
Nov 13, 2001 12:51 PM
