P1316 HELP NEEDED
Old Feb 28, 2012 | 10:49 AM
  #31
Studawg's Avatar
Studawg
Thread Ender
It was the IDM!!!! I got 2 bad ones, one used and one GB Reman.
Old Feb 28, 2012 | 11:36 AM
  #32
73ferdf250highboy's Avatar
73ferdf250highboy
how'd they figure it out? injector not do it?
Old Feb 28, 2012 | 02:42 PM
  #33
Studawg's Avatar
Studawg
Thread Ender
nevermind, still have the problem, it is not the IDM
Old Feb 28, 2012 | 03:04 PM
  #34
73ferdf250highboy
is there a way you could film it? reason being, i am having sorta the same issue. slight high speed miss. no codes. i've had the valve covers off sooo many times this week, it is no longer amusing.
the last time i ran her without the covers on- unplugged-then replugged my suspected injector and she smoothed out(for a couple days), but it is back.
my symptoms were at first a slight miss with a slow to warm hole. thought it was a glow plug cause she smoothed out as she warmed up. that was a few days ago. she does start right up but like your rig she is lumpy.
im wanting to ohm out my injectors. any ideas to what spec are?
kurt
Old Feb 28, 2012 | 03:16 PM
  #35
Studawg's Avatar
Studawg
Thread Ender
There would be nothing to show up on video. I am really the wrong person to ask about any specs, I am completely and utterly clueless on this matter.
Old Feb 28, 2012 | 03:29 PM
  #36
73ferdf250highboy
i understand. im to the point where i just want to slap a set of injectors in there and cross my fingers but at $250 each or $950 fer all of em. the wife isn't so anxious
Old Feb 28, 2012 | 03:48 PM
  #37
bfife's Avatar
bfife
still plays with trucks
before I'd spend the money on injectors, I'd swap the solenoid over to another injector to see if the code moves. that 1273 code says "high to low open" it should be electrical.
when mine did this it would set the CEL but run OK. I moved the solenoid to another pac and the code moved. bought a new pac for $60 and it was golden again. simple to do. 4 torx screws right on top.
Barney
Old Feb 28, 2012 | 03:54 PM
  #38
GoCamping's Avatar
GoCamping
Studawg I'm real curious which Diesel Mech you go to. I'm near Greenville and have only been to Fairway Ford...
Old Feb 28, 2012 | 04:01 PM
  #39
73ferdf250highboy
bfife, i was thinking the same thing. i dont have any codes, but when i use a temp gun on warm up #2 is slower to warm than the rest.
i wish i could go out there now and mess with it, but my 18 month old daughter refuses to let me.
i'll try swapping the solenoid when/if she takes her nap. lol
167k on her
kurt
sorry studawg, not trying to hijack
Old Feb 28, 2012 | 05:19 PM
  #40
BigAlsPSD's Avatar
BigAlsPSD
I understand this is frustrating, but did you ever try swapping the injectors or solenoids off of 3 to another? I know I have at least mentioned it a few times in your various threads, and others have also suggested it...Did your mechanic change #8? Did he change #3? What codes are you getting now, still the p1273? This really sounds like a solenoid issue...
IDI-Charlie
Mar 23, 2017 07:20 AM
davidlea
Feb 10, 2012 04:22 PM
davidlea
Dec 8, 2011 08:45 PM
snorindad
Aug 20, 2010 12:57 PM
machmedic
Mar 19, 2006 08:48 AM
