P1316 HELP NEEDED
Old Feb 20, 2012 | 01:04 PM
Studawg's Avatar
Studawg
Thread Ender
I think I have a bad or sticky injector.
Old Feb 20, 2012 | 02:26 PM
73ferdf250highboy's Avatar
73ferdf250highboy
i was having the same type of issue. slight miss when "cold" starting. no codes, (i have the little red superchip programmer thing) but bad mpg. i finally went under the valve cover to see what the heck is wrong in there. no shims & no money in there. anyways, i had the valvecovers off- lets start it to see if i had oil flow to all injectors: yes. unplugged the suspected infector. no change in cold, lumpy, missy idle. plugged it back in: miss went away- seems to run alot better! put about 25-30 miles on it yesterday. went out this morning "cold" started...she runs great, drove it a few miles no issues.
my guess was a sticky injector
my .02
kurt
99 7.3 4x4 cc drw
Old Feb 20, 2012 | 03:38 PM
Studawg's Avatar
Studawg
Thread Ender
My mechanic tells me he did a contribution test and that my #8 injector is bad. Cost to fix is between $500-$550. He said the price for the injector is $330.
What do yall think? Should I just do this myself? How much can I get that injector for? I have been into the driver side VC, is it hard to get the injector out?
Old Feb 20, 2012 | 03:49 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Very common for #8 to fail the CCT test even while #8 injector is operating correctly.
Your original code was for the #3 injector, correct? Did your mechanic find any other codes besides P1316?
I think I've asked this question before but forgive me if I forgot the answer....
The truck actually runs fine....correct? No other issues other than a random SES light?
Old Feb 20, 2012 | 04:07 PM
Studawg's Avatar
Studawg
Thread Ender
So I gathered after doing a little searching on here. Now im worried that isnt the problem. Yes the original code was 1273. He said he just got the 1316 code and that #8 failed the CCT. The truck actually does idle kinda rough. It will lope, or kinda rock back and forth a little.
Old Feb 20, 2012 | 04:21 PM
Shake-N-Bake
... It will lope, or kinda rock back and forth a little.
Perfect....now is the time to pull off both valve covers and start the engine. Observe the oil discharge spout on each injector and see if any appear to be different from the rest. Might want to pay extra attention to #3 (which will be nice and easy to see...)
Old Feb 20, 2012 | 04:31 PM
Studawg's Avatar
Studawg
Thread Ender
The truck is at the mechanic's, 17 miles away. I am at a total effing loss here. I dont know what to do. I already wasted money on an IDM because I thought that was it since it ran fine with my IDM in it. Now Im out a few hundred for that because I cant return it. I wasted time pulling both VCs only to find both connectors fully plugged in with ford shims in both side. Now a mechanic tells me I need a new injector, but I find out on here that that injector regularly fails a CCT. Meanwhile I got people calling me wanting to buy the truck because I have it advertised and I keep having to tell them all this and that its something minor but I cant figure it out. I am sorry to vent here, but I am totally frustrated and stressed to the effing max.
Old Feb 20, 2012 | 05:19 PM
73ferdf250highboy
not terribly hard, just kinda messy. make sure not to double washer.6.0L powerstroke injector(s) replacement - YouTube
this is on a 6.0 but not any different
paid $225 each from diamond diesel here in west sac.
i charged him $150 to do it.
kurt
Old Feb 20, 2012 | 05:37 PM
Shake-N-Bake
I can sympathize...
Well, if the mechanic will guarantee that #8 is bad and replacing it will solve your problem then maybe that might not be a bad option for you at this point...
If I was in your situation, I would put the replacement IDM in the Excursion...driving it around for a while until it gets good and hot and see if the codes return. If you don't get any codes after a week, then put the original (working) IDM from the Excursion in the truck and sell it.
Or....how much does a new IDM cost from the dealer? Is it less than $500? You said the truck ran fine with the IDM from the X so it sounds like you solved your problem already....perhaps it was just some bad luck and you got faulty replacement IDMs and that is throwing you off the trouble shooting process.
Old Feb 20, 2012 | 06:37 PM
Studawg's Avatar
Studawg
Thread Ender
I can sympathize...
Yeah, thats what Im gonna tell him. If he feels comfortable replacing that injector, knowing that if it doesnt fix the problem, then Im not gonna pay, then go for it. But im not paying him to be trained or experiment, Im paying him to fix the problem that I brought it in for.
Maybe it was bad luck, I just didnt think I could get two bad IDMs from two totally different sources.
Old Feb 20, 2012 | 06:43 PM
73ferdf250highboy
you could always just take #8 out move it to the front of the motor- restart see if the the miss follows. use a temp gun if you have one.
Old Feb 21, 2012 | 07:41 PM
joeyd61's Avatar
joeyd61
has this beed resolved??
Old Feb 21, 2012 | 08:23 PM
  #28
Studawg's Avatar
Studawg
Thread Ender
I told him to proceed with changing #8, should be done tomorrow. I'll be sure to post the results.
Old Feb 21, 2012 | 10:55 PM
  #29
bluescrew's Avatar
bluescrew
time for an oil change?
Old Feb 22, 2012 | 09:18 AM
  #30
Studawg's Avatar
Studawg
Thread Ender
that was the first thing I did when I got my hands on the truck
