gpr/ po hacking issue
Old Feb 16, 2012 | 01:06 PM
woodie92250's Avatar
woodie92250
i bought a f250 4x4 powerstroke yesterday its a 97. he said it had gp issues. it was clean it ran good i bought it.
so here i am i have studied the web read articles and have mechanical apptitude to one extent or the other.
it does have a new gpr u can tell, it was wired wrong, i start testing wires with my test light, i have batt, gp wires and two small ones a purple/orange, and a brown /red i believe. so... batt an gp i have covered. my confusion was when i tested the the two smal ones the purple/orange was dead. brown/red is ground goes hot w key.
(i do understand relays btw)
so i get to tracing things at actual relay/ fuse box i look down and low and behold there are two cut wires laying there a purple/ orange (i ohmed it it's the same wire) and a black/white( which is ground) . it appears they cut them coming out of the fuse box, it looks like they were run into the cab, i found a momentary toggle mounted to the dash( wonder why right/). so i can figure out how to rig it with a toggle its a no brainer, but i would like to fix it right so i have the timer..... is the purple wire my timer hot? (i checked it it stayed on for 5 min and never changed. also when i turn the key on i hear the realy kick on for the timer and the dash light stays on only 2 sec then goes off no matter hot or cold.... i will fix it eventually, but im hoping one of u have the knowledge to get me there faster. thanks oh and turns out the black has a yellow stripe not a white
Old Feb 16, 2012 | 01:19 PM
Hussler's Avatar
Hussler
Here is a simple diagram ...
Red/LtGrn is hot all the time with key on. PPL/ORG is pulled to ground by the PCM to activate the GPR and PCM is the timer. Either small wire can be on the small terminals as it's just DC. Wait-To-Start light is independent of GPR ON time. WTS light may come on for 20 seconds max (really cold) where GPR may be energized by the PCM for up to 2 minutes.
Old Feb 16, 2012 | 01:51 PM
woodie92250
Thanks that's what I needed to know, now I just need to find the other end of it and figure out wth this Guy did.
Old Feb 16, 2012 | 02:08 PM
Hussler's Avatar
Hussler
Here is a chart showing the GPR ON time vs EOT ...
genscripter
23
Aug 12, 2024 04:01 PM
ggadwa
6.7L Power Stroke Diesel
Apr 17, 2013 11:20 AM
10 sec brutus
Aug 29, 2010 11:08 AM
90F250CT
Sep 25, 2007 12:14 PM
Hiflyer746
Nov 17, 2006 10:38 PM
