Sponsored by: Auxito
torsion keys
Old Feb 14, 2012 | 02:11 PM
cjtim's Avatar
cjtim
torsion keys
i have a question just for saftey about changing torsion keys, any info on what to watch out for while unloading the presure off these? thanks
Old Feb 14, 2012 | 03:45 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Slow and steady, count the turns. When reinstalling the lift keys, resist the urge to just crank em all the way in. They need to be adjusted properly. Make sure the truck is supported on a good set of stands and is solid. You will probably need my two best friends, Oxy and Acetylene... Especially as I see you are from Illinois. The will likely be "rust welded" onto the end of the bars.
Old Feb 14, 2012 | 04:05 PM
cjtim's Avatar
cjtim
support the vehihicle under the frame soilid or the torsion bars? do i need have a floor jack under the torsion bars?
Old Feb 14, 2012 | 05:58 PM
degu2000's Avatar
degu2000
Yes. Jack the front wheels off the ground when you do this, otherwise you will have problems.. Also, IMHO, torsion keys are worthless; just crank your bars up.
Old Feb 14, 2012 | 07:46 PM
Archion's Avatar
Archion
Support it under the frame. And " just crankin' the bars up"is one of the stupidest things you can do mechanically. It places undue stress on the suspension components, especially the upper control arms, bumpstops and cv axles and can lead to greater issues/failures When installing lift keys, the factory ride height adjustment directions still apply, you just account for the amount of lift in the measurements. We went over this in a previous thread recently. A search should bring it up.
Here ya go... https://www.ford-trucks.com/forums/1...ot-issues.html
Old Feb 14, 2012 | 09:19 PM
steve(ill)'s Avatar
steve(ill)
If you go to change the keys, jack under the frame and let the tires hang, then back off on the factory screws. You can definitly just screw in the factory screws to raise the height. That is exactly what the aftermarket keys are going to do. It does absolutely nothing to increase stress on other components. All it does is twist the torsion rod which is basically a sping. As you twist harder, the truck rises. You have not increased the weight of the truck so no extra stress exists. It would be the same as putting an air bag longer coils, or air shocks on a coil spring truck. All the aftermarket keys do is reposition the torsion bar with respect to the jack screw so you can "screw it in further". Going "to far" can cause the front axles angle to be excessive and can lead to extra wear on the CV joints. That is due to the axle angle, not the key or the use of aftermarket parts. How far you lift and what is "excessive angle" depends on how you drive and what kind of CV joint / ball joint life you expect.
Old Feb 14, 2012 | 09:33 PM
steve(ill)'s Avatar
steve(ill)
Here are a couple photos of a guy who has adjustable helper springs on the front shocks and gets about a 4 inch lift. One photo shows the CV joint angle (several posts down). That looks "extream " to me.
Front axle angle too extreme??? - F150online Forums
Old Feb 15, 2012 | 05:01 AM
Archion's Avatar
Archion
If your keys are cranked all the way up to the point that the upper control arms are constantly in contact with the welded wedge of steel on the frame, it is a bad thing, can cause bends, cracks, etc in the upper control arm under heavy use and repeated impacts from daily use(potholes, speedbumps, trails). How does "It does absolutely nothing to increase stress on other components" apply to that? Plus it makes for a really ****ty ride, it allows the transfer of a lot more NVH into the vehicle...
Old Feb 15, 2012 | 06:21 PM
KING-RANCH02's Avatar
KING-RANCH02
Be ready to change the inner cv boots wen u install keys, I found with lift keys crank to there's 3/4" of stud left to tighten ull get noticeable height diff and won't ripp boots, although stock boots are a hard rubber universal replacements are like a silicon rubber and not as easy to rip
Old Feb 15, 2012 | 09:32 PM
steve(ill)'s Avatar
steve(ill)
Cranking the factory keys will lift the front end approx 1 inch. It will in no way overload the suspension, You will be along way from bottoming out the upper A- frame. The only way you might bottom out would be to use AFTERMARKET key which would allow a couple more inches of lift and that MIGHT get you to the upper limit of travel.. that would be too far as i already said.
Murph2006
1997 - 2003 F150
Dec 3, 2008 08:04 PM
kain
1997 - 2003 F150
Apr 28, 2007 08:39 PM
golfguy0912
1997 - 2003 F150
Jul 14, 2006 10:07 AM
ChiefsFan
1983 - 2012 Ranger & B-Series
Apr 7, 2004 04:58 PM
98f250lightduty
Jun 9, 2003 12:10 AM
