fuel problems i think need help
Old Feb 13, 2012 | 07:31 PM
captWarren's Avatar
captWarren
I have a 92ranger 2.3 engine has been rebuilt runs good then starts stumbling and missing and will pop out the exchaust then run good agin for awhile. I thought water or bad gas so removed tank and drained put back together and same problem wat do i check next and how
Old Feb 13, 2012 | 08:49 PM
critterf1's Avatar
critterf1
What are the stored codes, if any?
Old Feb 13, 2012 | 08:58 PM
captWarren's Avatar
captWarren
havent tried to get codes yet they are difficult with these old trucks
Old Feb 13, 2012 | 09:19 PM
KhanTyranitar's Avatar
KhanTyranitar
Not really, you can do it with a paperclip.
Old Feb 14, 2012 | 12:03 PM
captWarren's Avatar
captWarren
tried to get codes today no codes the light will not flash at all
Old Feb 14, 2012 | 01:41 PM
captWarren's Avatar
captWarren
still can't get any codes but when i disconnect the maf the engine smooths out and runs better for awhile. so i guess i should start there but something else is still not right
Old Feb 16, 2012 | 06:59 AM
captWarren's Avatar
captWarren
how do I check fuel pressure still seems like a fuel issue to me
Old Feb 16, 2012 | 11:14 AM
captWarren's Avatar
captWarren
checked fuel pressure toay. pressure is good 34-38 at idle so ful pump is good.I think i have a cracked head allowing water in combustion after warmed up but i have good compression on all cylinders 145-150 and they don't leak down. bottom of engine was completely rebuilt but used the old head just lapped the valves. should have junked the truck instead of rebuilding
Old Feb 16, 2012 | 12:14 PM
powersmoked's Avatar
powersmoked
your fuel pressure might be a little high.....please post the results of the following tests.your results should be?
koeo 35-45
koer 25-35
koer with vacuum line off of the FPR 35-45
after engine is turned off the pressure should not drop more than 8psi in 5 minutes
pull the vacuum line of the FPR and see if there is vacuum on it and/or if there is fuel in the line.
Old Feb 16, 2012 | 02:38 PM
captWarren's Avatar
captWarren
I redid the fuel pressure test it is ok
koeo 40
koer 32
koer vacum off 42
pressure rop 2lbs after ten minutes
during the test this time radator cap was off engine was spitting water out. started supttering after 4minutes fuel pressure stayed the same
mattv150
13
Dec 27, 2012 07:24 PM
hunter01m
Sep 2, 2006 07:44 AM
ryantremblay
Dec 1, 2004 07:58 PM
Tommy Shadrick
Mar 18, 2004 01:28 PM
