ok so you know i was haven trouble with my rough idol at some point, well i notice it only when i get hot then tune off the motor and start it up itll do it, and when it get really hot from wheeling and i turn it off then later start it up it idol really rough. but when its cold when i shut it off and on its fine, and im loosing water. So its gota be the head gasket right
Maybe the IAC valve is acting up, dirty fuel injector, fouled plug. Could run a compression test to see if any cylinders are low . Is your temp gauge showing a normal read or is it running hot?
yeah the coolant looks find, and yes ill do a compression check this Saturday, iv check all my plugs and there find to and iv always ran EFI cleaner and ran another bottle hopping to fit the problem but no luck and my IAV valve had been unplugged cus it revd my motor to high and them temp is on the cool side untell i got up hill or something
hows your radiator ? it could be clogged up with gunk in the bottom and cousing a over heating problem !
hows your radiator cap ? if it is shot then you could be losing water and over heating !
hows the cooling fan and clutch ? if the fan aint pulling enough air over the radiator then it will get hot !
and if you do have moisture coming out the exhaust then dose it come out all the time or just when the engine is cold as in the mornings ? if all the time then I would pull the heads and proceed with checking the heads and or gaskets !
nope it dosnt over heat at all, i just mean when it heats up itll do it, But now that iv ran the liquid glass through it, it seemd to help the problem, and iv flushed my system a few times and have a new cap and thermostat
Maybe the fuel in the fuel rail is vaporizing from engine heat and leaking at an injector that makes it run rough till you get the fuel line pressurized and fuel running through it again. Take a fuel line pressure read cold/hot engine. Also check your clutch on the radiator fan to make sure it is operating correctly.
