Sponsored by: Real Truck
trans help
Old Feb 13, 2012 | 03:51 PM
chriselec75's Avatar
chriselec75
trans help
My 05 f250 is kicking a trans code of 962&657 . What do i do to fix them. Where do i start
Old Feb 13, 2012 | 07:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Those are not valid codes.
Old Feb 13, 2012 | 08:05 PM
chriselec75
Just double checked codes are p0657 & p0962. They are trans codes
Old Feb 13, 2012 | 08:13 PM
joe_r_dog's Avatar
joe_r_dog
i think he meant they werent full codes. with that last post, he should know. after all, he's the best!!!
Old Feb 13, 2012 | 09:52 PM
jk080's Avatar
jk080
Transmission Rebuilder
Code P0657 is actuator supply voltage A circuit / open. It means that voltage to the solenoids has been interrupted.
Code P0962 is pressure control solenoid circuit malfunction. The PCM detected a short to ground circuit condition on the Pressure Control solenoid 'A' circuit.
My guess is that there might be a short in the wiring harness involving the pressure control circuit. Look for worn spots in the harness especially around clamps or on corners, any place that might come in contact with the harness. Also make sure all connection to the trans are secure and clean.
Old Feb 14, 2012 | 07:03 AM
chriselec75
Thanks. Ill keep yall posted. Time to eash the mud our from under it. I live down a 2.5 mile dirt road that stays wet.
Old Feb 14, 2012 | 07:05 AM
chriselec75
Sorry ment wash
Old Feb 17, 2012 | 06:16 PM
chriselec75
Well here is what wr found. The wire harness in the trans thr insullation was worn though 800 dallors later. Witch that did inclued fluid and filter change.
Old Feb 17, 2012 | 06:18 PM
chriselec75
We. The. SOrry sending this from phone
Old Feb 17, 2012 | 06:21 PM
joe_r_dog's Avatar
joe_r_dog
Nothin to be sorry about. So is it all good now?
Old Feb 17, 2012 | 06:31 PM
chriselec75
Parts are overnited. Will be here on monday.HOPEfully
chriselec75
Thanks for all yall's help
Old Feb 23, 2012 | 04:44 PM
chriselec75
Well after replaceing internal trans harness,trans harness from pcm to trans,and the pcm.Also changrs trans fluid ,both filters,and the voltage side of ficum.A grand total of 2336.89 it was finished today.
Old Feb 23, 2012 | 04:59 PM
chriselec75
Also changed
blk88notch
May 25, 2021 09:53 PM
limptera13
May 5, 2010 08:58 PM
jethro
Sep 12, 2001 11:51 PM
96f150
Mar 20, 2001 04:57 PM
