codes!
Old May 5, 2010 | 05:03 PM
limptera13's Avatar
limptera13
codes!
finally got the codes off the trans id tag....
i think these are accurate but they were a little worn, so a 8 could be a B etc
Rts bz jg1
e6trra 0905
Old May 5, 2010 | 05:09 PM
limptera13's Avatar
limptera13
and the door sticker says trans code b but i dnno if the tranny is stock or not
Old May 5, 2010 | 05:25 PM
limptera13's Avatar
limptera13
i think its T170FT trans, more info on that please
Old May 5, 2010 | 06:26 PM
fepowerguy8's Avatar
fepowerguy8
does this help? Ford Toploader transmission - Wikipedia, the free encyclopedia
Old May 5, 2010 | 07:42 PM
limptera13's Avatar
limptera13
ya i ran into that, that picture is a lil different caue my shifter is on the top towards the front
Old May 5, 2010 | 07:44 PM
fepowerguy8
Well what exactly are you looking for for info, maybe I can be of more help?
Old May 5, 2010 | 08:00 PM
limptera13's Avatar
limptera13
well the adapter broke thats between the trans n t case, n i wanna find that peice so i can keep what i got, but if i cant find it, which ih avent, then i wanna put a diff trans in, whether its auto or manual, whatevers easier or cheaper
Old May 5, 2010 | 08:58 PM
Franklin2's Avatar
Franklin2
B is the overdrive RUG or hybrid toploader.
Here's a site that has the info on your tranny, and if you read down through, you will find the Tremec built toploader had the 170F lettering on the tranny.
Toploader 4 Speed Transmissions
From what I gather in the above link, you might find a jeep with the part you need also, if they have the same bolt pattern on the transfer case.
