When you guys are towing a big load (9k ish) on the express way what do you gauges read? At just under 2k Rpm @ about 68-70mph my EGT is 700-800 range, boost is usually around 4-6. Just checking to see if this is normal.
Sounds perfectly normal to me. I would expect boost to be a little higher, but if that reading is on flat ground it sounds fine to me, I'm just used to driving in a hilly area.
Originally Posted by bulla
I can only wish my temps were that low towing!
9k is not what I would consider a big load, but thats pretty close to what I run pulling 14k with 250/200 injectors.
