Towing and gauge question.
Old 02-13-2012, 11:00 AM
Bpayton's Avatar
Bpayton
Bpayton is offline
When you guys are towing a big load (9k ish) on the express way what do you gauges read? At just under 2k Rpm @ about 68-70mph my EGT is 700-800 range, boost is usually around 4-6. Just checking to see if this is normal.
Old 02-13-2012, 11:07 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Sounds perfectly normal to me. I would expect boost to be a little higher, but if that reading is on flat ground it sounds fine to me, I'm just used to driving in a hilly area.
Old 02-13-2012, 12:33 PM
Bpayton's Avatar
Bpayton
Bpayton is offline
Yes this is on flat ground. On a hill the boost will quickly rise to 10 or more.
Thanks for the reply I just wanted to see if I was in the ball park.
Old 02-13-2012, 12:44 PM
bulla's Avatar
bulla
bulla is offline
I can only wish my temps were that low towing!
Old 02-13-2012, 03:06 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
9k is not what I would consider a big load, but thats pretty close to what I run pulling 14k with 250/200 injectors.
Old 02-13-2012, 04:03 PM
Bpayton's Avatar
Bpayton
Bpayton is offline
I have stock injectors with a 60t tune. Truck has 190k on it
Old 02-13-2012, 04:32 PM
bfife's Avatar
bfife
bfife is offline
still plays with trucks
yep, I'm moving almost 30K when I'm rollin and those temps are about right on flat ground.
Barney
MAD
08-30-2013 01:20 PM
bluefin
6.7L Power Stroke Diesel
23
04-17-2012 06:43 AM
hschiro
10-18-2011 01:02 AM
seanjackmc
6.4L Power Stroke Diesel
09-15-2010 04:31 PM
hndacr
07-07-2010 02:53 PM
Quick Reply: Towing and gauge question.
