Question about towing numbers
Old Jun 14, 2010 | 11:01 AM
hndacr's Avatar
hndacr
This weekend was my first time towing since adding gauges, deleting the egr cooler, rebuilding the oil cooler, and cleaning the turbo. I was towing a 7500 lb travel trailer. The majority of the time I was running 70 mph with about 12 psi boost and 950* EGT. EOT and ECT was about 11* spread while towing. However, a couple times while coming up a small grade, the boost was only running about 6 psi and the truck did not downshift. The EGT's would rise to about 1100* as long as the TC stayed locked up. If I would really lay into the pedal, the truck would down shift and boost pressure would come back up and the EGT would come down. I found this rather odd. I also saw the boost hit 32 psi a few times under heavy acceleration when downshifting. Almost feels like the vanes could be sticking again, especially when just cruising along and the boost would drop around 6 psi. Does any of this sound normal? What is considered too hot for EGT?
Thanks!!!
Old Jun 14, 2010 | 12:23 PM
droffan's Avatar
droffan
Thanks!!!
I tow for a living with a 04' 6.0. Just towed a 32' fifth wheel from Elkhart Indiana to Stockton California with few to no issues. Weight was right around 11k. When towing "the grades" you just need to let the rpm's stay at a constant. I ususlly run about 22-2500 when doing the grades. Don't overwork it and try to beat the Dodges up the hill. Tranny and turbo running in conjunction is a sweet thing. Just don't over rev it. Too many gauges makes for a nervous driver imo, don't have any extra myself. If the idiot light isn't on all is good.
Old Jun 14, 2010 | 01:17 PM
bpounds's Avatar
bpounds
The EGT of 1100 sounds fine. I have my first alert set at 1200, and that's just because I like to see it come on once in a while. You can run at 1200 all day long.
I'm concerned with your boost. The 6 lbs does not sound like enough, just reading between the lines of your description, and a stock truck should not go above about 28 lbs. The gauge might just bounce up to 32 lbs once in a while, but if it runs there that is too high. I think you nailed it with the sticky vanes.
I don't see any issue with not downshifting. Were you running in tow/haul mode?
Old Jun 14, 2010 | 01:26 PM
hndacr's Avatar
hndacr
I was in tow/haul mode. Doesn't that make the TC stay locked up longer. I agree about the boost dropping to around 6 psi now and then. I did notice that when the boost was low, the EGT's were higher. When the boost was that low, the truck would only accelerate if I really got into it and it downshifted. If the vanes are sticking, I will be a bit pissed as I just cleaned that darn turbo. The turbo was a bit pitted though.
Old Jun 14, 2010 | 01:27 PM
tex25025's Avatar
tex25025
Actually I can tell you stories where not having the idiot light on and still had problems. I wouldn't assume that just because the idiot gauge isn't on doesn't mean that you don't have problems. Also extra gauges doesn't make for a nervous driver, it just makes for a more informed driver.
Oh by the by, I too also haul for a living ~16k worth of horseflesh and other related goods that goes along with that.
Old Jun 14, 2010 | 01:30 PM
bpounds's Avatar
bpounds
Tow/haul should make it downshift sooner, and hold a gear longer before upshifting. I'm not sure how it affects lockup.
My truck would run more boost than that for sure when towing. I haven't towed yet since I put the gauge in, but I have the dash boost gauge in my '06. I am pretty sure it would be more than 6 lbs even on flat level highway, and my trailer is smaller than yours.
Old Jun 14, 2010 | 02:10 PM
hndacr's Avatar
hndacr
It seemd to run around 12 psi or so most of the time. Once and a while it would drop to 6psi. I assumed the vanes were open a bit too much. I agree that is way to low as it runs 7 psi unloaded at 70 mph. I might have to keep an eye on it. I would hate to have to replace the turbo!!
Old Jul 7, 2010 | 09:33 AM
PrsrizdSD's Avatar
PrsrizdSD
I would like to ressurect this post because I was going to ask about my boost numbers too. I have only towed with my truck twice(just got it), and this second time was after I had installed 35" tires. Just wanted to find out if my number was okay. I pull about 7500-8000 lbs. While on the flat areas running 65 to 70, by boost would run about 10 psi. If I hit any grades and wanted to maintain speed, it would move up to about 17 to 20psi until over the hill. Ocasionally it would downshift until the road leveled back out. Does this sound about right?
Old Jul 7, 2010 | 09:42 AM
bpounds's Avatar
bpounds
I think that sounds about right. If it is pulling the load well, those numbers sound good.
As a point of reference, my truck won't boost much over 20psi in overdrive. Apparently it just can't use any more air than that at the lower RPM's. But when it downshifts is when it will jump to 28psi, and that's as high as it goes. Some of them will only do 26psi, no matter what, and that seems to be dependent on the PCM flash. Anything around 25-28 as a maximum is okay. These trucks should not go higher than that, even though the gauges redline at 35psi. (stock tuning only)
Old Jul 7, 2010 | 10:05 AM
69cj's Avatar
69cj
I might also add that in the 25 to 30 psi range the boost gauge is a little ambiguous in its spread.
Old Jul 7, 2010 | 02:18 PM
brickie's Avatar
brickie
I lifted both heads at 35psi (tuned without studs),so take Bills word for the max safe boost.
Old Jul 7, 2010 | 02:23 PM
tex25025's Avatar
tex25025
Oh it's too bad y'all can't experience 50psi of boost, blow off the turbo downpipe. It's a wonderous thing.
Sorry about that OP, I just can't help myself at times.
Old Jul 7, 2010 | 02:30 PM
brickie's Avatar
brickie
Tex I had a ultra comp that would boost 42+ Matt had to re-write it to get the boost under control as in his words boost that high could gernade the stock turboBut holy smoke does that much boost get a 4 ton truck hauling azz!!A safe 50 must rock once it spools up.
Old Jul 7, 2010 | 02:53 PM
tex25025's Avatar
tex25025
You know, I've never had his ultra comp tune. I had his street comp tune and that was a fun ride and it was a pretty good economy tune as well. That one tune did generate some improvements for me. I mainly just use his hybrid race tune and tow tune. I think at one time, I had about 7 different tunes.
Dave,C
15
Jul 1, 2014 07:02 AM
Superduty450
6.4L Power Stroke Diesel
13
May 29, 2014 10:02 PM
ScaldedDog
54
May 7, 2012 10:18 PM
ForemanES
Mar 4, 2008 12:23 PM
PowerstrokeJunkie
40
Jul 29, 2007 11:54 AM
