Fuel problem
Old Feb 12, 2012 | 06:44 PM
Roncberry's Avatar
Roncberry
Fuel problem
My 1995 F250 7.3 Turbo quit running today from lack of fuel. Both tanks have plenty. On my lsat fill-up I added a diesel supplement Which I had never done before. I have no idea if that has anything to do with my problem. I would appreciate some ideas as to where to stare looking before I start buying parts. Thanks
Old Feb 12, 2012 | 08:58 PM
Moes641ton's Avatar
Moes641ton
Check the rollover switch i believe it is located in the passenger kickpanel mine has tripped once I replaced it havent had a problem since.
Old Feb 12, 2012 | 09:28 PM
Roncberry's Avatar
Roncberry
Roncberry fuel prob
Thanks Moe I have never heard of a rollover switch but you can bet i"m looking for it now.
Old Feb 13, 2012 | 04:56 AM
732t37's Avatar
732t37
Think the owner's manual calls it a "fuel-pump cutout" or "inertia switch". If you look it up it'll tell you exactly where it is.
On my 1991 gasser it's sorta under the brake pedal.
Old Feb 13, 2012 | 12:29 PM
Roncberry's Avatar
Roncberry
I need help finding the fuel shut off valve or fuel-pump cutout switch. It is not in the passenger side kick panel. 1995 F250 7.3 turbo diesel. Thanks in advance.
Old Feb 13, 2012 | 12:43 PM
Dave804's Avatar
Dave804
If that doesn't fix it:
Getting fuel to the engine? Power to fuel pump? Fuel pump running?
Mikemusial
Sep 16, 2014 09:52 PM
EatBeef
6.4L Power Stroke Diesel
Feb 11, 2011 06:19 AM
richtree
1997 - 2003 F150
Nov 28, 2008 06:03 PM
damyankee
Jun 21, 2004 01:53 PM
Doxy
Jul 11, 2003 01:45 PM
