Changing from 6volt to 12 volt G.P.
Old 02-11-2012, 11:49 PM
mudguts's Avatar
mudguts
mudguts is offline
Hi I was wondering if anyone had done this? and what all is involved? I'm thinking as I still have my engine out, if all I have to do is change the spade style connectors out. and the GPS, I might as well do it. Thank You in advance. Mudguts
Old 02-12-2012, 08:04 AM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
be sure that your GPs and their controller are designed to work together, and you'll be fine. if your controller is designed for 6v plugs, it'll have trouble warming up 12v plugs as the plugs won't be getting enough voltage
Old 02-12-2012, 08:15 AM
mudguts's Avatar
mudguts
mudguts is offline
Thanks, I went to a manual switch after my Autolite Experience. lol. i think I will keep the switch and just go with the 12 volt plugs also better safe than sorry. Mudguts.
Old 02-12-2012, 12:33 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
You'll need the glow plug wiring harness from an '87 6.9 or any 7.3 engine.
Junk yard will be your best bet.
Old 02-12-2012, 01:51 PM
mudguts's Avatar
mudguts
mudguts is offline
Thanks I appreciate the info. Mudguts.
Old 02-12-2012, 03:24 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
You can also just keep to manual spade style plug...btw...i find that the ZD-9's are cheaeper than ZD-1s
Old 02-12-2012, 07:46 PM
mudguts's Avatar
mudguts
mudguts is offline
Thank You.
Old 02-13-2012, 06:44 AM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
Are the ZD9's a 12v plug?
Old 02-13-2012, 07:59 AM
mudguts's Avatar
mudguts
mudguts is offline
I dont know?
Old 02-13-2012, 11:11 AM
IDIDieselJohn
ZD9 is for the solid state system 87+ so yes, 12V
The ZD1's are the old spade connector 6V ones.
Old 02-13-2012, 11:48 AM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Lets get the facts straight ...
<table><tr><th>Beru Glow Plug Specifications</th><th></th><th></th><th></th><th></th></tr><tr><th><b>Type</b></th><th></th><th><b>GV 823 (ZD9)</b></th><th></th><th><b>GV 835 (ZD1)</b></th></tr><tr><td>Order Number</td><td></td><td>0 100 271 101</td><td></td><td>0 100 271 102</td></tr><tr><td>Thread Size</td><td></td><td>M 10 x 1.00</td><td></td><td>M 10 x 1.00</td></tr><tr><td>Length of Glow Plug</td><td></td><td>81</td><td></td><td>78.5</td></tr><tr><td>Reach</td><td></td><td>28</td><td></td><td>27.5</td></tr><tr><td>Hex</td><td></td><td>9.5</td><td></td><td>9.5</td></tr><tr><td>GP Nm</td><td></td><td></td><td></td><td></td></tr><tr><td>Connect max. Nm</td><td></td><td></td><td></td><td></td></tr><tr><td>Volts</td><td></td><td>10.5</td><td></td><td>10.5</td></tr><tr><td>Amps</td><td></td><td></td><td></td><td></td></tr><tr><td>Seat</td><td></td><td>Conical</td><td></td><td>Conical</td></tr><tr><td>Connection</td><td></td><td>Pin</td><td></td><td>Blade</td></tr></table>
-Enjoy
fh : )_~
Old 02-13-2012, 07:35 PM
mudguts's Avatar
mudguts
mudguts is offline
ThankYou for all the help. MudGuts
sawmaned
05-11-2017 12:53 AM
we287gn
01-04-2015 06:42 PM
dirtman2
13
11-23-2010 10:39 PM
CBMS
01-26-2009 09:45 PM
bigfootsurfin
10-18-2008 08:43 AM
Quick Reply: Changing from 6volt to 12 volt G.P.
