Sponsored by: Real Truck
Should I be concerned?
Old Feb 11, 2012 | 10:32 PM
rock hugger's Avatar
rock hugger
Trailering
I put a new unit bearing on back in August, since then the ball joints went out. I know I should have done them at the same time. So tonight I pull it apart to find the unit bearing I put in spewing grease out of it, this assy only has about 5k since I installed it and I didn't buy the cheapest one I could find either.
They are the precision brand and ran about $260. each. Should I return these and buy a different brand? What do you guys recomend? How do I post pics on the mobile version of the board?
Old Feb 11, 2012 | 11:41 PM
rock hugger
Trailering
Let me try this
Old Feb 12, 2012 | 12:08 AM
SpringerPop's Avatar
SpringerPop
Those of us that routinely pump grease into our hubs have this happen all the time. We don't have to replace them as a result.
Wipe it off, pump some more in, and press on. Mobil 1 synthetic grease is a good one to use.
Don't forget to grease those needle bearings, too, while you're at it.
Pop
Old Feb 12, 2012 | 12:24 AM
rock hugger
Trailering
How do you pump grease in them? They don't have a grease zerk anywhere.
Old Feb 12, 2012 | 12:26 AM
SpringerPop
You can grease things that don't have a zerk. It's not required.
Pull the ABS sensor.
Here's some reading for you that may save you some money:
https://www.ford-trucks.com/forums/9...-bearings.html
Pop
Old Feb 13, 2012 | 12:59 PM
rock hugger
Trailering
Thanks for the info. I went ahead and got it replaced anyways from Kragen. I think it was an off brand put in a precision box, the new one is a Moog, hopefully it will be better and I will Grease them like your write up.
Is the amount of grease that comes on the spindle bearing enough or should I add more to it?
Ricko
May 24, 2018 11:28 PM
RV_Tech
All Things Towing
41
Dec 26, 2015 10:16 AM
ac700wildcat
Apr 22, 2010 03:17 PM
patsplace
18
Feb 18, 2008 10:09 PM
MAXEY
Jul 20, 2005 03:17 PM
