Sponsored by: Real Truck
Power Window Question
Old Feb 11, 2012 | 06:44 PM
Harold Graham's Avatar
Harold Graham
My 05 Super Duty crew cab driver's side power window has decided to quit! It is making a grinding noise like gears are misaligned.
I have the inside door panel off, and the plactic or rubberized plastic off, too. I also removed the door speaker to access the motor. I believe I see the bolts holding the motor onto the door.
Before I get over my head I was wondering if anyone on the forum has been here before and might guide me.
I have no problem digging into it but digging out of my forays especially without previous knowledge is costly...and my window could still be stuck down!
Old Feb 12, 2012 | 12:54 PM
dennis350's Avatar
dennis350
It's not always the cost, it's the pain, the regulator arms are under a lot of pressure and you need to lock the sector gear before you remove the motor, you can do that by putting a bolt and nut thru the backing plate and sector gear to lock them together
Rich G
Apr 22, 2017 09:51 PM
jimford1
1978 - 1996 Big Bronco
Apr 21, 2009 08:32 PM
mh34444
Bronco II
Jan 17, 2008 05:26 AM
JohnT
May 12, 2006 08:15 PM
YankeeFan
Jun 9, 2004 06:00 PM
