wiring problems
Old Feb 12, 2012 | 03:50 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by kedwinh
It all depended on what motor the truck came with, the 4.9 started in 84. 87 was when most, (all?), went EFI. But they had the Feedback carb/TfI computer setup before that. The harness your describing sounds just like the computer harness on my 4.9. I don't know enough to tell you what motors did or didn't come with computers that year but a lot of people on here do. If you only have the chock wire going to your carb then it would be a DSII ignition probably, and should have a vacuum dizzy if they did the complete change over. But I'm betting your truck came with a computer, and probably still has it mounted under the dash. I'm thinking the 2 wires still connected are gauge sensor wires.
The Federal 49 state 4.9L and most all other engines became EEC-IV, TFI-IV computer controlled in 1984.
California State 5.0L and 5.8L was EEC-III, Duraspark-III in 1980. And the 4.9L was MCU (microcomputer contol Unit) DS-II in 1981.
Originally Posted by 84F150XLT
it has a 2v carb on it now..and i know the smog crap was bypassed. i am going with whisler's explanation, that someone did a conversion and didnt pull the harness. i like that better then he just hacked up some wires..haha
I concur, and if this in fact the case, the harness can be unplugged from the computer at the other end inside the cab and done away with. You will have to find the gasket to cover the hole through the firewall though.
Old Feb 12, 2012 | 06:01 PM
84F150XLT's Avatar
84F150XLT
how many wires should be going to the cab on a carbourated truck??
it as a canadian truck, i live in canada
Old Feb 12, 2012 | 08:29 PM
whisler's Avatar
whisler
As far as the ones to the computer , it is a bunch, but they are all in one harness. I "think" there are two harnesses that go through the firewall, one to the computer and one for everything else.
Old Feb 14, 2012 | 07:31 AM
84F150XLT's Avatar
84F150XLT
turns out there is a computer uder the dash...my teacher said something probably we nt wrong with the efi so for simplicitys sake the PO just swapped manifolds over to a carbourated one? sound reasonable?
now should i just tuck all them wires where they were or yank em and pull the computer??
Old Feb 14, 2012 | 09:59 AM
whisler's Avatar
whisler
'84 F150, 351W would not have been fuel-injected, but did have the electronic feedback carb and computer controlled ignition (TFI). The feedback carbs were notoriously bad for not idling properly and being difficult/impossible to adjust.
Probably the PO did what I did and switched back a few years to the standard 2150 carb and Duraspark II ignition. This eliminates the need for the computer for carb and ignition, but with those two things out of the system the computer wouldn't know what was going on with the emissions. So I (and probably your PO) just pulled all the emissions stuff.
But then why leave all those useless wires and vacuum hoses in the engine compartment. Here's where my route differed from your PO; I pulled all the wires through the firewall and disconnected them from the computer and also removed the computer altogether. Your PO must have decided on the more expedient route of hacking the wire harness at the firewall and leaving the computer were it was.
To each his own, as they say.
As to your question, I would trace the two wires that you say are still connected and see were they lead. If they go to the computer,then they are not needed, yank them. If they go someplace else you better verify what they are doing, before you do anything you may regret. I like things as uncluttered as possible, that's why I pulled the wires and computer completely.
Garrett24
Nov 21, 2017 04:22 PM
flagator
1983 - 2012 Ranger & B-Series
Dec 30, 2014 02:07 PM
daddykitty
Mar 17, 2013 04:31 PM
z1121jack
May 13, 2010 09:17 PM
gstowe1
Aug 28, 2002 08:54 PM
