The tires on the front of my F-250 4x4 look like this \ /. All of the stuff on the front is about 2yrs old and probably not driven for more than 20k and I have kept the alignment up as well. I used Moog on all of the ball joints, tierod ends, drag links and pit man's. I have done the bearings and seals as well.
What causes this and how do I fix it?
Reason: Tow = Toe ;)
You say Toe-in, but when you say \ / it makes me think your camber. Camber is how the wheels tilt out at the top or tilt in at the top, toe-in is how narrow the leading edge of the front tires are compared to the back of the front tires.
So, if you were looking down on the truck from above, you're saying the tires would look like
--1--
^^^ That?
A little bit of toe in is necessary to help keep the vehicle from wandering on the roads. Excessive toe-in can lead to tire wearing issues.
If your tires look excessively "toe-d" in, I'd say take it to a reputable alignment shop and see what they say.
Does the truck have a lift or bigger tires than stock?
No, it would be the camber angle then. It looks like this \ / from the front as if it is going to do some severe wearing on the inside of the front tires.
Make sure you drive forward on level ground before you get out and look at it. If you back up or are parked on a hill, the front tires on a ttb do weird things. If that's not it, it sounds like you have installed a "leveling" kit on it, and they can't quite get the alignment in spec because of it.
I wonder if the front leafs are just shot? The front end shop told me I might need to install some different camber bushings or camber bushings ball joints or something like that.
Why didn't they do that? It will cost you a little bit of money for the bushings, but if it's not too bad it should bring it in correctly.
The upper balljoint is not mounted directly into the spindle, but it's mounted into a bushing that surrounds the balljoint, and the bushing then fits into the spindle. These bushings can be bought with different "offsets", making them look like a cam. When the alignment guy spins these bushings around, it actually moves the position of the upper balljoint and can correct alignment issues if they are not too bad.
Ok, so I was wondering if there were different degrees of these bushings or not. Sounds like a bushing is somewhat adjustable though. I wouldnt let them put them in b/c I thought they wanted too much for them. So I need to put some in it and take it back to the alignment shop is what it is sounding like.
They do come in different degrees. You will need to let them pick the right ones. They need to have some experience in doing this, and/or the alignment machine software will tell them which bushings they need to install. They have to to use the same bushing to get the caster and the camber in the ballpark, all in one operation. If they gave you a readout from the previous alignment, they may be able to figure out what to order from that.
I just put some new springs on my truck to lift the front about 1-1/2"-2", and had the same camber issue. I ended up getting a set of adjustable camber bushings (from Bronco Graveyard) and had my alignment guy install them when he did my alignment. I believe that they took care of my issue.
Why, oh, why couldn't our trucks use "A" arms...? So much easier to set caster, camber and toe. I have a longacre tool that we use on the race car and it works like a charm.
You have to admit they are easier than what we have on our trucks. And by easier I mean I'm more familiar with them. Bahahahaha
Seriously though, IMO "A" arms are easier to work with than the TTB system Ford decided to go with.
I would have to agree with that statement. That being said, I think Ford trucks ride more like trucks than Chevy trucks, which ride more like cars. That's just my opinion though.
