Sponsored by: Real Truck
Drilling the Receiver
Old Feb 9, 2012 | 10:10 PM
barthel's Avatar
barthel
Hey All,
Dumb question for ya. I wanted to mount some "utility" lights on the *** end of my truck. I want to mount them to the receiver towards each end in order to get the best light spread.
Question is, if I drill 2 small holes for each light does that weaken the receiver?
Opinions?
Old Feb 9, 2012 | 10:21 PM
dkf's Avatar
dkf
I'd just put some paint in the holes after you drill them to help prevent rust. The tube will twist and bend somewhere else first more than likely. Or drill and tap the hitch and screw in bolts to attach the lights. Holes on only one side of the tube and the bolt will prevent the hole from collapsing.
Old Feb 9, 2012 | 10:40 PM
barthel's Avatar
barthel
That's pretty much what I had planned on doing. I just wanted to make sure I wasn't going to weaken the hitch by doing so.
Thanks dfk!
Old Feb 9, 2012 | 11:37 PM
MisterCMK's Avatar
MisterCMK
Can you use a beam clamp to mount the lights?
Old Feb 10, 2012 | 01:06 AM
Kajtek1's Avatar
Kajtek1
Generally on each beam it is safe to drill pretty big hole in the center away from ends. When you drill close to the end, that will weaken the beam drastically.
Typical sample are TJI floor joints. You can cut 5" hole in the center of the beam in the middle of the floor, but 2" hole close to the wall can be a problem.
Old Feb 10, 2012 | 01:37 AM
PITS's Avatar
PITS
I looked at mounting on the receiver/hitch bars but found a better spot closer to the corners since that is where you need the light.
Old Feb 10, 2012 | 01:47 AM
barthel's Avatar
barthel
Thought about that, but I liked the idea of mounting them on the receiver as it tucks them up under the truck, not visible unless you're looking for them.
Old Feb 10, 2012 | 02:10 AM
PITS's Avatar
PITS
Are you trying to hide them for security purposes or asthetic purposes?
I red locktite'd them on and even filled the machine head screw pits with it so someone would have to physically cut them off to steal them. If I ever need to take them off, I have plenty of time and tools to do so. A common car prowler will not be prepared (unless he read this... ).
Old Feb 10, 2012 | 02:39 AM
twags6's Avatar
twags6
They're better protected mounted under the hitch. Out on the corners, its easier for them to get smacked by something the tires kick up or knocked off if you accidentally back into something....like a rock hard snow mound in my case.
Old Feb 10, 2012 | 05:44 AM
sammy77's Avatar
sammy77
I've done the same before and they seem to work the best in the spot versus the hitch area.
Old Feb 10, 2012 | 07:17 AM
Banage's Avatar
Banage
I have mine on my reciever hitch. I love how they cant be seen and work great. The little curve that the hitch is made with points them perfect
Old Feb 10, 2012 | 07:20 AM
ThirdCoastStroker's Avatar
ThirdCoastStroker
If you dont want to drill use these, this is what I have on my F350 they ty wrap to the hitch and they are solid and great light lights, never had any problems with em yet, and i have had them submerged under water once already
Amazon.com: Navigator Backup Lights: Automotive
Old Feb 10, 2012 | 08:11 AM
Furian's Avatar
Furian
You Keep What You Kill
You could use a high strength "epoxy" on the mounting brackets as opposed to drilling/nuts/bolts.
Old Feb 10, 2012 | 08:35 AM
Parts Jimmy's Avatar
Parts Jimmy
I have a mount that I use to secure my truck camper that slides in my hitch's ends. You could make a mount using a shorter piece of tube that fits inside the hitch though.
DAVE67FD
Mar 18, 2015 10:08 AM
kc0stp
All Things Towing
15
Mar 6, 2013 04:14 PM
jwhopson
Dec 23, 2012 11:20 PM
jim mills
Aug 8, 2006 10:13 AM
stebab
Mar 8, 2006 04:27 AM
