RUST
Old Feb 10, 2012 | 07:59 PM
Joe Bloomingdale's Avatar
Joe Bloomingdale
Originally Posted by vtown00
Did you take the springs and everything apart to coat it all?
I had the truck apart doing the new 6" lift, I coated everything before I put it back together and also did the springs for good measure. Believe it or not the springs are the only thing rusting right now in between the leafs where I couldn't reach without taking them apart. Everything else is doing great.
Old Feb 10, 2012 | 09:14 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
FYI... Over in the Tech Folder, Stewart saved this thread: https://www.ford-trucks.com/forums/1...l#post11373735 which will take you here: https://www.ford-trucks.com/forums/5...ml#post3945171
Old Feb 14, 2012 | 09:12 AM
BostonX73's Avatar
BostonX73
I've tried to repair the doors like the link mentions a few times before. Scraped, sanded and cleaned it all, then painted it up. Problem comes back in 6 months or so. Like I said my truck was previously outside year round. This summer I would go and check it after a decent rain and would find water inside the door. If you move the door or put a towel up there you could get it to come out the drain holes. Seems to me this is what is causing the most damage. That water works down the seam inside and starts the whole works rusting. Not sure if the drain hole can be drilled out a little lower or not. Don’t want to seal that all up and loose the drain holes. Guess would be best to stop the water from getting in to begin with.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Feb 14, 2012 | 09:17 AM
Lowboy44's Avatar
Lowboy44
Originally Posted by Joe Bloomingdale
I used Por-15 on everything underneath the truck after years of rusting, doesn't really need a whole lot of prep but should be top coated if parts will be in the sun. The stuff turns chalky and starts to break down somewhat. It takes forever to come off your skin and is pretty expensive, but a little does go a long way. I will definitely use it again.
I agree. I've used it on a couple past projects. It's very thin and watery. So be careful when applying,it will run. A little does go a long way. It's very durable. It it is VERY difficult to get off your hands..Good luck
Old Feb 14, 2012 | 09:40 AM
vtown00's Avatar
vtown00
Thanks can't wait for spring/summer now
Old Oct 29, 2013 | 01:40 PM
AndrewWV's Avatar
AndrewWV
Originally Posted by Snowseeker
I buy the little 6 pack deals of por-15. The cans are like 4 oz. each.
I did my doors when I got the X but went all out to get the rust out before coating. I wanted to make sure it was right the first time.
POR-15 in the door, in between the metal seam, and on the outside.
I then painted it all white again. To do something like these doors right you have to get all the flaky rust out or it will just hold moister and junk causing more rust.
Hey, Andy. I'm curious how this is holding up. I did this last year and it came back. Not sure if I didn't scrape it enough or if I left room for water to get into it from the back side.
Old Oct 29, 2013 | 07:06 PM
Snowseeker's Avatar
Snowseeker
Mine has been looking good so far but I store it during winter. One of these days I am going to make up a wand with a jet on the end so I can spray the insides of rockers and doors and whatnot.
Old Oct 29, 2013 | 07:52 PM
housedad's Avatar
housedad
DINE17149-10 Nozzles ( Box of 10 ) - DINITROL - Manufacturer | Lubricant Supplies
DINITROL EXTENSION SPRAY NOZZLE 600mmLONG FOR FITTING TO AEROSOL CAN | eBay
PLCguy
Jan 19, 2017 07:53 PM
67nukeford
Nebraska Chapter
Dec 5, 2008 04:46 PM
tolmite
Jun 22, 2007 11:39 AM
tastyklair
Paint & Bodywork
Aug 14, 2006 08:46 AM
j gibbs
May 9, 2005 12:06 PM
