anyone painted over rust bullet?
Old Jul 12, 2006 | 01:34 PM
tastyklair's Avatar
tastyklair
One of the options I'm looking at is painting over Rust Bullet as a primer. Any one have experience with it? They say it is a good adhesion promoter.
Old Jul 22, 2006 | 05:41 PM
99f350sd's Avatar
99f350sd
Just scuff it up and paint away...RB is the best primer you can use over sand blasted metal. I think I've got a good combo for new metal or rusted metal. Its Picklex first then rust bullet. I think its much better than just rust bullet...
Dick
Old Aug 7, 2006 | 03:14 PM
johaner78's Avatar
johaner78
On my 1978 F250 Crewcab frame, I had it sandblasted, then sprayed on Rust Bullet then topcoated with Napa's Chassis Black color. I love the Rust Bullet product!! Good adhesion promoter if you spray on the top coat BEFORE Rust Bullet cures. If it cures out, then you will have to sand/scuff the RB. On my frame, I didn't want to spend the time scuffing, so I topcoated while the Rust Bullet was still tacky. The topcoat has actually bonded with the Rust bullet - you can't scratch it off!!! Was a good method of doing the frame. Whatever topcoat you use, just be sure to spray on BEFORE RB cures. If not, then start scuffing and paint should stick too.
Old Aug 11, 2006 | 12:37 PM
brucewolff's Avatar
brucewolff
Are we talking about frame work or exposed finish side of body panels and does it make any difference?
Bruce
Old Aug 11, 2006 | 02:21 PM
tastyklair's Avatar
tastyklair
I'll be doing both. I should get to doing the inside of the cab next weekend. The outside of the cab may be a month or so yet and the frame probably not until spring. Rust bullet claims that their product wouild be considered a mid level primer with excellent adhesion. If you don't top coat right away you have to scuff it up.
Old Aug 11, 2006 | 02:40 PM
johaner78's Avatar
johaner78
tastyklair - save your self some work and topcoat when RB is still tacky if you can. RB cures like concrete and it will take some considerable effort to scuff by hand. If you don't scuff the RB, the paint will not stick. To remove RB from things that you don't want it on ----- you have to grind it off. I got some on my hands when I was cleaning my spray gun with xylene and i wore this stuff for 3-4 days!!! Otherwise, I love the product. Good Luck!
Old Aug 11, 2006 | 04:10 PM
99f350sd's Avatar
99f350sd
As per rust bullets directions I would be carefull which top coat you use before the rb has cured. It dries by absorbing moisture you don't wanna mess with that. As said above it may work with certain paints although I woudn't do it, it sands real easy. I'm on my 6th gallon of the stuff..
Dick
Old Aug 14, 2006 | 07:34 AM
johaner78's Avatar
johaner78
99f350sd what do you use to scuff up the rust bullet?? by hand or machine? just curious. seems like a lot of work. My case was I had a frame from a 78 crewcab that showed rust pitting after I had it sandblasted (which is good all the rust is gone). Then when I went to spray on RB, it still left a porous, rough surface (the rust pitts). It would have been next to impossible to get down into all the pores to get the RB scuffed so my top coat would stick. That is why I sprayed on the Chassis Black when RB was a little tacky yet (couldn't pick up any on your fingers when you touched it). Think it worked just fine.
Old Aug 14, 2006 | 08:46 AM
99f350sd's Avatar
99f350sd
I think 150 grit paper you don't have to get into all the cracks thats impossible. make sure you use 2 coats or more of rust bullet..The chasis black may have had something in it to cause the rb to cure. Some paints won't work in that situation.
Dick
jayfire1988
Oct 14, 2015 04:43 AM
Coastal68
Sep 14, 2015 07:50 AM
vze2sgxa
26
Apr 18, 2012 04:22 PM
green53
Feb 19, 2011 07:49 PM
Billyclub
Nov 22, 2009 05:36 PM
