trans problem help
Old Feb 8, 2012 | 05:09 PM
zckattkisbck's Avatar
zckattkisbck
trans problem help
i have just purchase a 94 f150 2wd with 5.0 not sure what transmission is in the truck. iv tryed searching but no luck. but here is my problem from a start to about 40mph i never here the transmission shift and if i accelerate past 40mph the truck just reves as if it was not in gear. any suggestions would be gratefully appricated thanks
Old Feb 8, 2012 | 05:55 PM
danr1's Avatar
danr1
Sounds like its a E4OD with problems with either the MLPS, VSS or PSOM.
Verify which trans it is by pan,
Ford Transmission Pan Shapes
Then run the self test, see what if anything it gives to go on. It might not throw a code however always best first place to start.
Fuel Injection Technical Library » How To Run a Self-Test
Old Feb 9, 2012 | 11:57 AM
zckattkisbck
aod 14 bolt pan
Old Feb 9, 2012 | 05:17 PM
bashby's Avatar
bashby
Did you try shifting it manually? Pull it down in 1st, run the rpms up, then shift to 2nd and so on.
Old Feb 9, 2012 | 05:32 PM
danr1's Avatar
danr1
Check for proper adjustment/operation of the TV cable, if you haven't looked into that yet I'd start there.
If not sure how to set cable a simple "Google" search something like "AOD TV cable adjustment" will return many hits video and otherwise type "how to" on the subject.
Old Feb 10, 2012 | 09:16 AM
zckattkisbck
tryed shifting manually it just stays in same gear never shifts but im thinking the tv cable does need adjustment because wen im in reverse the dash says im in park and wen in nutral says reverse and so on so possible adjustment is needed thanks for the info . will try adjusting today and see what happens
Old Feb 10, 2012 | 09:21 AM
bashby's Avatar
bashby
tv cable goes from throttle body on the engine to trans. It has nothing to do with the indicator.
Old Feb 10, 2012 | 10:38 AM
subford's Avatar
subford
Are you sure that you have a 1994? A 1994 did not have the AOD transmission, maybe a 1993?
As for the indicator that sounds like loose screws down near the floorboard.
Old Feb 13, 2012 | 04:48 PM
zckattkisbck
ok my friends there were a couple bolts loose n now tightend. the truck will now **** 1st n 2nd but no o/d. wen i press the o/d button the truck acts as if its in nutrual and just revs up till i press the button again... and suggestions on this problem? btw i tryed the computer self test and came up with 1 code 53 wich was tps signal low thanks guys
Old Feb 13, 2012 | 06:53 PM
jk080's Avatar
jk080
Transmission Rebuilder
This truck will have the first year for the 4R70W transmission, it basically is a electronic AOD, it also has a 14 bolt pan that is shaped like the AOD, and no TV cable.
The reason why it feels like it shift to neutral on the 3-4 shift is because the overdrive band is applied and the forward drum is released. So if the band cant hold it free wheels because the forward clutch released.
If I had to guess I would think that the band inside your trans is burnt and that your trans will have to be rebuilt. I would see this failure over and over in our shop.
Old Feb 14, 2012 | 05:36 PM
zckattkisbck
i found a AOD trans online for 200 bucks but its out of a 92 f150 do you think this will work in my truck also is there any other transmission that will workk in my truck say a mustang trans for instance?
Old Feb 14, 2012 | 06:54 PM
subford's Avatar
subford
If you have an OD button you do not have an AOD transmission.
So NO a AOD out of the 92 f150 will not work in your truck.
Old Feb 15, 2012 | 06:42 AM
zckattkisbck
so what transmission will work??
Old Feb 15, 2012 | 06:45 AM
bashby's Avatar
bashby
Another 4r70w would be eaasiest. The aod would"work" but you would likely spend more on extra's to make it work (computer, etc) than just getting the same trans as you have now.
Eric
Dec 25, 2018 02:13 PM
bigal7562
Jan 6, 2011 06:36 PM
Supercab
Apr 9, 2008 07:47 PM
ricku
1978 - 1996 Big Bronco
May 21, 2007 08:38 AM
macian
Sep 20, 2004 01:37 PM
