I've got a '99 Ford Ranger 3.0L that has check eng. light on.
Problem is I can't get the code reader to pull up the code. This has happened before and someone told me how to jump 2 of the leads in the link connector then I was able to. But like a dummy I didn't write it down. Anybody got an answer for me. Thanks!
Mine is doing the same thing. the general readers like you get for fairly cheap do not work. My cousin brought home a code reader from the place he works....one of the $1500 ones. It would not work until we used the extra power lead and plugged it into the cig lighter. With mine at least it seems to be the power lead part of the obd hookup. Dont know if its related, but my radio switched power does not work either.
I have power at the obd11 fuse, and my wiring diagram has a pin 16 at the "data control link" whick is solid orange but no power there. At the data control link I have power at pin 9 which isn't shown in my wiring diagram. ( the wiring diagram link you sent to me to blue oval parts)
I have taken it and used someone else's code reader and no luck. More suggestions?
Thanks!!
I have been looking at my fuse box for 2 days trying to figure out what fuse i needed to change to get my OBDll to read. I have the official manual to fix my expy, but I dont speak mechanic tech so i was kind of lost checking all the fuses, I thought i had, but after reading this post I went to the manual and boom located the exact fuse, pulled it, and BLOWN. Thanks again.
Holly aka knix
Reason: bad wording
This is certainly good, however fuses don't blow without a reason. You could have had a bad one of course, but you might not be done investigating.
I had a "the edge" in it. I was hoping for fuel economy at the time (not preformance) and I am hoping I did something bad when I was tinkering with that that would cause it to blow. OR since this fuse also works one of the cig lighters, My kids use them for misc mobile items, and I am thinking they might have messed it up (blown fuse).
If its not one of those two things, I will be back here searching for. "blown fuse" obdll
The manual 30.00 useful
Not having to go to the mechanic for a rip off repair satisfying
but this webpage is Priceless.
Welcome to FTE.
Check the in cabin "Cigar Lighter" fuse & the fuses sockets, as the DLC power lead also shares this fuse & if it's bad or pulled, the wire is cut, the DLC pin is damaged, ect & not making connection, a scantool will not work as it gets it's power from the vehicle through this circuit.
look for OBD-II connector pin assigment and check voltage supply and ground of connector.... Fortunatry '99 ford cars and trucks have OBD-II connected directly to electronic unint w/o gateways (like Mercedes trucks use INS ore Grund Module on later trucks as gateway to communicate with other modules)...
Well. Do you see power LED on your scanner. Does communication led blinks when U try to pull codes and OBD data?
