Booster Problems?
Old Feb 7, 2012 | 05:55 PM
Jay_Sliver's Avatar
Jay_Sliver
Booster Problems?
G'Day boys and girls.
My name is Jay, and i'm a noooob (here at least). I MOD over on an S-series forum.
Anywho, the Van is my In-laws business delivery van. It is a 1998 E350 with a 7.4 Powerstroke. I suspect the brake booster has gone for a crap, as it has all the typical booster going for a crap symptoms. I would like to first and foremost check the vac pump to make sure it is pulling the correct amount of vacuum, and also to check the booster check valve, before I pull the booster. My question is, does anyone know the spec for the amount of vacuum that the vac pump should pull? I have all the tools and whatnot to do the job (I am a Farm Equipment Mechanic, or Diesel Ag-Tech).
Thanks,
Jay
Old Feb 7, 2012 | 06:25 PM
Jay_Sliver's Avatar
Jay_Sliver
Wholly crap threads get buried fast here. Guess that's a good thing to have though. Lots of activity is a good thing.
Jay
Old Feb 7, 2012 | 07:25 PM
732t37's Avatar
732t37
I realize it's highly unscientific but I usually just put my finger over the rubber hose coming off the pump to see if there's vacuum in the first place. In my experience these things either work 100% or not at all.
Old Feb 7, 2012 | 07:35 PM
Jay_Sliver's Avatar
Jay_Sliver
Yea, I pulled the vac line off the booster, and there is Vacuum there, I just wanted to make sure. The in-law says its good for about 2 brake applications, then the pedal goes rock hard. Slip it into neutral, rev it up a little, and the pedal starts to come around again. Im 90% sure its the booster.
Jay
Old Feb 7, 2012 | 08:11 PM
blageurt's Avatar
blageurt
A weak vacuum pump or vacuum tree leak also causes those symptoms.. Does the heater controls work properly...the default postion is Defrost On a Diesel , Hard pedal ussually points to the pump....If the pedal goes all the way to the floor it is usually the booster or if your hear a hiss....I forget the spec on the vacuum but if you post on the Diesel forum someone will know....
Old Feb 7, 2012 | 09:44 PM
Jay_Sliver's Avatar
Jay_Sliver
I will have to have a look at the heater controls tomorrow night. I guess if the mixer doors are slow or inoperative, it would make more sense to look for a vac leak, then the pump. Does everything come off the vacuum manifold mounted just under the cowel?
Jay
Old Feb 7, 2012 | 10:01 PM
blageurt's Avatar
blageurt
Yes it comes from the back of the pump to the tree and the from the tree to the booster and other lines.....you have to check all of them...Mine was acting funny and the light ( brake) was slowly coming on and going away when it was cold (-10C)...It was the spring clamp on the tree going to the booster that was a little weak. I put a regular hose clamp instead and it stopped...be careful that plastic can be brittle....
Old Feb 11, 2012 | 09:01 PM
Jay_Sliver's Avatar
Jay_Sliver
Well, I replaced the booster today. Problem still exists. No vacuum leaks at the vacuum manifold below the cowl. All the spring clamps are still good and strong and not sprung or warped in any way shape or form.
I made a thread over in the diesel section inquiring about vacuum pump specs and how much vacuum it is supposed to pull.
Thanks for everyone's info and advice.
Jay
Old Feb 15, 2012 | 09:17 PM
Jay_Sliver's Avatar
Jay_Sliver
Just a little update... 7 in Hg is not enough vacuum to make anything work the way it should. Spec is 17-21 in Hg.
Ordering a vacuum pump tomorrow.
Jay
Old Feb 16, 2012 | 01:38 AM
joshofalltrades's Avatar
joshofalltrades
i think mine pulled close to 25" last i checked, but the range you posted should be plenty. if you're only getting 7, thats where the problem is.
Old Feb 17, 2012 | 08:38 PM
Jay_Sliver's Avatar
Jay_Sliver
Put the Vac pump on it tonight. Brakes work like a charm...heater controls too.
Thanks guys for all your input and ideas.
Jay
biglou71
Feb 8, 2014 01:10 PM
jbrown9709
Dec 7, 2009 03:00 PM
Stroker Ace
Apr 18, 2008 06:22 AM
1poorboy69
Oct 29, 2006 05:30 PM
MSC
13
Jul 10, 2004 06:31 PM
