Brake Problem?
Old Apr 18, 2008 | 02:30 AM
Stroker Ace's Avatar
Stroker Ace
Brake Problem?
When I push the pedal down it doesn't want to come back up without help.Power booster was replace 1yr ago,as well as vacuum pump. Any ideas? Thanks alot!
Old Apr 18, 2008 | 06:22 AM
Cuda_jim's Avatar
Cuda_jim
Low vacuum may cause this. Are your defrosters stuck on defrost?
If not, the booster is likely bad again. There is a vacuum valve and a light spring the booster that helps the pedal return.
Hopefully the booster is still under warranty if that's the case
