Lights only half working
Old May 20, 2012 | 02:19 PM
Jamie Arceneaux's Avatar
Jamie Arceneaux
Yes. High beam fuse was so loose inside the fuse block it wasn't making contact. I had to put two metal strips on each side of the fuse to snug it in. No troubles since doing that.
Old May 20, 2012 | 11:33 PM
empiretc's Avatar
empiretc
Thanks! Will check that tomorrow!
Old Jan 6, 2013 | 09:31 PM
empiretc's Avatar
empiretc
so truck needs to get inspected and never corrected this problem on mine.
replaced the fuse and checked it with a test light. everything looks good.
however, when I click on the hi-beams, the lights go out.
is there a way i can test the switch?
Old Jan 7, 2013 | 07:26 AM
empiretc's Avatar
empiretc
bump..... need some ideas
Old Jan 7, 2013 | 10:41 AM
howellt39's Avatar
howellt39
I don't know much about this particular switch. If I were in your position and time was an issue you could buy a known good one and swap it out. If it works you're on your way, if no change you've eliminated the switch as the culprit.
Old Jan 7, 2013 | 11:58 AM
empiretc's Avatar
empiretc
yeah, but was really wondering if there was a way to confirm the switch is dead.
the fuse lights the test light when the hi-beams are turned on, even though it kills the headlights.
Old Jan 7, 2013 | 12:54 PM
PaysonPSD's Avatar
PaysonPSD
Does the high beam dash indicator lamp come on. It is powered by the same fuse. LT GRN/BLK wire. If the HI beam indicator is not coming on there is a problem at fuse 16 underhood.
Same color wire going to the head light bulb connector for high beam. Pull the bulb connector and use your test light to see if the battery is getting all the way to bulb.
If you don't have DRL you can just ignore that portion of wiring diagram.
1999-2001
File Type: pdf
Old Jan 7, 2013 | 01:45 PM
empiretc's Avatar
empiretc
1999-2001
Thanks Robin. Yes, the Hi-beam indicator on the dash comes on, and I replaced fuse 16 just to be safe. It lights the test light like it should.
I will get under the hood with test light and see what I can find out. No DRL.
Old Jan 7, 2013 | 02:03 PM
empiretc's Avatar
empiretc
Was able to do some quick test.
Upgraded the headlights in old green back in 07, and added this at the time:
9007 to 9008 Headlight Heavy Duty Wiring Harness Upgrade
checked power on original plug, and there is power where there needs to be. this makes me believe it is one of the relays of the harness. will tear further into it when time and weather permits.
Sf jakey
Nov 15, 2017 07:02 PM
crashrowland
Dec 26, 2016 09:13 PM
wagon burner
1997 - 2003 F150
15
Oct 21, 2004 09:18 AM
DMac875
Electrical Systems/Wiring
Dec 3, 2003 03:31 PM
Truck_Chic
Nov 15, 2002 07:14 AM
