ipr
Old Feb 6, 2012 | 09:04 AM
jerkypants's Avatar
jerkypants
ipr
If you unscrew the ipr from the valve cover, should there be oil?
Old Feb 6, 2012 | 09:22 AM
69cj's Avatar
69cj
The icp is in the valve cover.
Old Feb 6, 2012 | 10:01 AM
jerkypants's Avatar
jerkypants
Ok, that is what I meant. Should there be oil there?
Where is ipr on an 05 f350 td?
Old Feb 6, 2012 | 10:12 AM
BLADE35's Avatar
BLADE35
If the oil has came threew the Middle if the sensor and is now on the wire pigtail this is not mormal sensor should be replaced
If you unscrewed the sensor from the valve cover and then the oil cazme out the bottom then this is normal
the IPR on an 05 is under the turbo
KRDiesel
Jul 20, 2014 12:23 PM
Stevo88
Oct 10, 2013 08:57 AM
bebeard
May 12, 2012 10:01 PM
mudbug04
15
Jul 16, 2009 03:48 PM
CRJ900
13
Dec 20, 2001 01:14 AM
