viberate
Old Apr 22, 2003 | 01:42 PM
WADDELL's Avatar
WADDELL
viberate
My 92 F150 4X4 viberates at 40 mph.When I let of the gas or go faster its not nearly as bad.Its hardly noticeable at 70mph.I just instaled new gears ,could it have something to do with the drive shaft?I would think if it was a tire it would do it at all speeds.
Old Apr 22, 2003 | 01:53 PM
billman's Avatar
billman
viberate
Last time I had something like that, I had a tire out of balance.
Old Apr 22, 2003 | 05:04 PM
McLeod's Avatar
McLeod
viberate
A gear change affected my front drive shaft. Can't run hubs in @ freeway speed until shaft was rebalanced.
Old Apr 22, 2003 | 06:17 PM
balingwire's Avatar
balingwire
viberate
Pull your U-joints out and check them for wear. I had a similar vibration and that was my problem. However, my vibration was not severe, just aggravating.
Old Apr 22, 2003 | 07:37 PM
steve83's Avatar
steve83
viberate
It could be the driveshaft, u-joints, or even the pinion nut or gear setup. Get whoever built the diff to recheck everything.
Old Apr 22, 2003 | 10:13 PM
eckart's Avatar
eckart
viberate
If your slip joint is within the driveshaft make sure your u joints are in phase.
Old Apr 23, 2003 | 11:53 AM
PARKER1234's Avatar
PARKER1234
viberate
I HAVE 35" TIRES ON MY 87 F-150 AND WHEN I DONT ROTATE THEM ON A REGULAR BASIS IT WILL DO EXACTLY WHAT YOU ARE SAYING
bohiaa
Oct 6, 2009 08:58 AM
charter
1978 - 1996 Big Bronco
Jun 1, 2007 12:19 PM
jekin
2004 - 2008 F150
Jan 19, 2007 01:02 PM
rjdpowerstroke
Nov 7, 2005 12:23 PM
