Plumbing Question
Old Feb 3, 2012 | 05:34 PM
smokewagun's Avatar
smokewagun
Plumbing Question
I'm changing to a larger well tank. My old setup has PVC between the well tank and the pipe that comes from the well. Supply pipe through the house is copper. Is it necessary to use PVC for some reason? In case the wellhead is struck by lightning current won't pass through the house? Noise transmission? Im thinking about all copper after the galvanized barbed fitting from the well supply. Is that okay? Thanks.
Old Feb 3, 2012 | 08:51 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
I dont know of any reason that the PVC has to be there. I would guess it was a matter of convenience when the well equipment was originally installed? Vibration resistance maybe?
Old Feb 3, 2012 | 09:19 PM
Bruker's Avatar
Bruker
My house has a similar set-up. It was probably done that way because it was easier to deal with all the short runs and connections by using PVC. Do whatever you feel most comfortable with.
Old Feb 3, 2012 | 09:57 PM
planehunter's Avatar
planehunter
I'm guessing that the PVC makes it easier to work around, but you also have to deal with 'galvanic corrosion' when you deal with copper and galvanised steel, and natural water chemicals. I would use the same set up.
Old Feb 3, 2012 | 10:23 PM
732t37's Avatar
732t37
Other than the fact copper plumbing costs up to six times as much as PVC, there's no reason you can't use either.
Oh, and apparently living in California causes you to get cancer if you drink from PVC. So keep that in mind.
Old Feb 4, 2012 | 07:59 PM
lariat97's Avatar
lariat97
PVC is better in my opinion. Copper degrades over time plus it has lead in all the connections. It your PVC breaks its easy to fix. There are a few new types of pope also. PEX is one
Old Feb 4, 2012 | 08:44 PM
85e150's Avatar
85e150
Lead-free solder is available and works fine for plumbing.
Old Feb 5, 2012 | 08:51 AM
lariat97's Avatar
lariat97
Sharkebite connections work great for many types of pipe. You can join pvc &copper with them. No lead & very easy to use
Old Feb 5, 2012 | 09:32 AM
fred_79f250's Avatar
fred_79f250
Originally Posted by lariat97
Copper... has lead in all the connections.
Lead-free solder isn't just available and work fine - building code requires that you NEVER use leaded solder for soldering water supply piping in a home. They make lead-free solder specifically for that. It's as common, or even more so, than leaded solder. There's no reason or excuse for having lead in your water supply lines.
Old Feb 5, 2012 | 09:36 AM
fred_79f250
The flexible plastic hose between your pump and the plumbing serves several purposes:
- as a vibration damper to isolate the pump from the rigid copper plumbing - makes it quieter and gentler on your joints
- insulating galvanic action between the copper plumbing and the non-copper fittings at the pump
- the flexibility takes up any minor mis-alignments between the pump outlet and the copper line, taking stress off the fittings - it can be tough to get them lined up perfectly with the pump attached to those great honkin' well hoses.
Be sure to use hose with braided pressure-reinforcing.
Old Feb 5, 2012 | 09:08 PM
lariat97's Avatar
lariat97
I work in a 60 year old state park. It has lead in all the copper joints. We are replacing it with PVC.
Old Feb 5, 2012 | 10:02 PM
smokewagun's Avatar
smokewagun
Thanks for the replies. For the little bit of piping, cost isnt the issue. What I see right now is weird corrosion on the PVC that looks like bubbled up battery acid on the PVC joints. Why? I'm afraid if I touch it, it will start leaking or crack. That's why I thought I'd switch. I never considered a braided flex connection, but will certainly add one. We have terrible black iron that has coated all interiors of our copper, so before I install the new well tank, I'm putting a whole house filter before the tank. Thanks for the replies.
Old Feb 5, 2012 | 10:15 PM
732t37's Avatar
732t37
That sounds like the joints on the vinyl pipes weren't made properly. It's pretty easy to do, but you MUST follow the rules. Work fast, no water for 24 hours, twist each piece 90 degrees, don't be cheap with the cement, etc.
I would also like to add for any other readers out there, it is a myth that you should let the purple primer dry before putting the cement on. Apparently a lot of folks think this is the right way. If you do that you may as well not use the primer, the whole point is to soften the vinyl so it can mix with the cement. I've seen a fair amount of bad joints that were the result of improper cement application.
Old Feb 5, 2012 | 10:18 PM
732t37's Avatar
732t37
Either that or your water is so toxic it has already turned you into a demented monster forever consigned to avoiding society and spewing BS on Ford Truck Enthusiasts all day. At least, that's what happened to me after I ignored the warning about drinking that really tasty water last year
ford2go
Aug 29, 2013 06:38 AM
bcjim
Sep 27, 2008 06:22 AM
ckal704
Apr 23, 2007 07:07 PM
horse_trader
Jan 30, 2006 09:20 PM
CowboyBilly9Mile
Oct 25, 2005 12:29 PM
