Plumbing question
Old Sep 25, 2008 | 08:42 AM
bcjim's Avatar
bcjim
Plumbing question
I am getting a sewer odor in my home, seems to be associated with my upstairs bathroom. Seems to come and go. Seems (and Im not sure about this) to be worse after heavy water use, evening showers etc..Was out of the house last weekend and little or no smell when we returned.
Im planning to change the toilet ring, anything else it could be? Blocked vent? Seems like it would be constant if that were it.
Other info- Downstairs bath is being renovated (by me slowly) and little water is going down those drains right now but there is a separate vent stack for that bathroom and no smell in that part of the house. The smell did start after I demo-ed the shower and stopped using it though.
Id really appreciate some advice..
Old Sep 25, 2008 | 09:38 AM
buckeyebronco's Avatar
buckeyebronco
P-traps being empty will let the smell into the house. Depending on where the trap is for you shower it could be dry thus letting air through it. Also sounds like a vent may be partially clogged. When you are using alot of water the dry or almost dry p trap mixed with a slightly clogged or undersized vent may be forcing air out where it is not supposed to go. Best bet, cap the shower drain line first and see what happens.
Old Sep 25, 2008 | 12:23 PM
bcjim's Avatar
bcjim
I'll try that and the toilet ring. No idea how I would check my vents, smoke?
My other fear is that its a dead animal hiding in my wall or roof..but Im pretty sure it is the plumbing.
Old Sep 25, 2008 | 04:41 PM
Buck 1's Avatar
Buck 1
10 to 1 the traps are empty and letting the odor back into the house. Run some water into the traps and that will block the release of the odor. That should do it!
Old Sep 25, 2008 | 05:38 PM
lariat97's Avatar
lariat97
I just finished remodeling my baths. I took the p traps off to repair the sheetrock around them & to install my cabinets. I just taped them up good & it stopped my odor problems. Run a water hose down your vent pipes & flush them out good if you think they might be clogged. I think you would be having slow draining of your pipes if the vents were blocked.
Old Sep 25, 2008 | 08:09 PM
Svets96's Avatar
Svets96
You could try and put some bleach down the pipes, I had this odor too, it does put a temporary fix to it. But it helps. Does keep everything clean inside as well.
Old Sep 26, 2008 | 07:58 AM
lenny1carl's Avatar
lenny1carl
assuming you've got a separate vent stack for upstairs i'd start there. if it's plugged, animal, leaves, pine needles, anything..heavy water use could siphon one of the upstairs traps dry.
Old Sep 26, 2008 | 08:19 PM
medhvac's Avatar
medhvac
what there saying is check all your drains! Ive never seen a vent clogged in all my years of cleaning sewers!
Old Sep 26, 2008 | 09:25 PM
sierraben's Avatar
sierraben
Did you eat any Mexican food?
Is the waste water flowing alright?
If not, maybe a dry stack may be plugged?
Old Sep 27, 2008 | 06:22 AM
mistakenID's Avatar
mistakenID
The overflow in bathroom sinks can get pretty stinky. Fill the basin and then drain, does the smell get worse?
Mix bleach and water, about 4-1 and pour into the overflow to kill the bacteria. DO NOT use bleach if any type of drain cleaner has been used recently.
dcf4x4
Jun 18, 2010 03:06 PM
krewat
22
Oct 22, 2005 09:06 PM
Bruker
Aug 15, 2005 11:30 PM
TN-W124 Diesel
May 23, 2005 02:41 PM
73highboy4x4
23
Jun 30, 2004 06:07 PM
