Sponsored by: Auxito
Yes or no ?
Old Feb 2, 2012 | 11:21 AM
ole_smokey_88's Avatar
ole_smokey_88
Yes or no ?
Ok I know this question has been asked a billion times but I'd like to know for sure. I have a 2002 f-150 5.4 ltr with the 4r70w transmission the truck has 118,000 on it and the trans has never been serviced. I've heard the horror stories about changing the filter and fluid after 100k.
So I guess my question is should I service it or not I plan to use the mercon 5 motorcraft and a motorcraft filter am I making a mistake or not ?
Thanks in advance
Ole smokey
Old Feb 2, 2012 | 05:00 PM
enriched&beyound's Avatar
enriched&beyound
Thanks in advance
Ole smokey
Ya I was in the same quandary.
I had a shop change the filter after I had them do a flush with new fluid....yeah i cost me more fluid...in this way I knew I got all new fluid and the old filter caught any crustations that got shook loose during the flush.
If I had to to it again, I might get 2 filters , use 1 before the flush...do the flush...then change the filter again. In this way a fresh filter is sacrificed for the flushing and not washing new fluid through a old filter.
Old Feb 2, 2012 | 06:10 PM
steve(ill)'s Avatar
steve(ill)
the porblem comes in on doing a power flush on an old transmission that might have burn builup inside on the case. THe crap can break off and then go thru the valves. It is never a bad idea to drop the pan, wipe off the valve and pan, clean the magnet, change the filter, reinstall the pan and add 5 quarts of NEW oil. I dont think the 2002 has a converter drain plug so the other 8 quarts stay in the converter system. At least you get 35% of the oil new, refresh a few addatives, and get the crud buildup off the valve and out of the pan.
Old Feb 2, 2012 | 07:55 PM
firefighter1416's Avatar
firefighter1416
I wouldn't did my 2000 at 100000 and at 104000 new tranny coincidence maybe but I'm not gonna bet another $2500 on it!
Old Feb 2, 2012 | 10:18 PM
00GT's Avatar
00GT
Did you have it power flushed or did you just change the filter and add fluid?
I agree with Steve. I would just drop the pan and change the filter. If you flush I think your asking for it.
Old Feb 3, 2012 | 01:06 AM
ole_smokey_88
Ok guys thanks for the info my fluid is still nice and red it has good consistency but I just want to do it before its really to late and it costs me a new trans I've almost got the truck paid for and I plan on keeping it for a while
And when I change it I'll drop the pan and clean everything in very precise when it comes to stuff like that
Old Feb 3, 2012 | 03:50 PM
cjtim's Avatar
cjtim
had a shop change n flush my tranny at 100,000 miles, well as it hit 102,000 tranny went out, il never do a full change again just the pan oil
Old Feb 3, 2012 | 05:30 PM
firefighter1416
Just dropped the filter put a new one in and refilled.
Old Feb 3, 2012 | 06:06 PM
enriched&beyound
Hmmm guess I got lucky then, IDK?...I got nearly 12,000 miles on since doing my tranny and still going strong.
jobberone
Oct 6, 2019 04:05 PM
MY1STCREW
2004 - 2008 F150
46
Feb 20, 2009 12:50 AM
ag-ford-4x4
2004 - 2008 F150
Jan 10, 2008 11:04 AM
IneptMechanic
1997 - 2003 F150
Apr 9, 2007 12:11 PM
robbieie
Jan 3, 2004 05:14 PM
