why not just go with a ford balljoint... i seem to be leaning toward manufacturer parts being way better than aftermarket... the extra cost is most likely worth it.... i know factory brake pads are way better that the ones from autozone or wherever.... last so much longer
I noticed that about the MC brake pads to I was very Impressed with OEM Brakes
I thought that Moogs were supposed to be Good
And another reason I selected Moogs Over OEM was the MOOGS were Greasable plus a Life Warrenty
Im Not 100% shure But I think that you can get a MC ball joint thats Greasable now
Yep just looked at Oreiylies they had an MC upper BJ that was Greasable didnt see a greasable lower but they didnt have a Pic of all the MC ones
Have to be careful Looks like they had MC Non greasable and MC Greasable ones but only a 1 year warrenty
I usually do alot of research on all the parts I use and have come to the conclusion that It just depends on the part some are Better off to stick with OEM like the air cleaner,oil filter,fuel filters ect.... and some are Better AM Like a BPD EGR Cooler would be one instance here another would be a DC Power Alternator would be better than OEM
Just have to do the research and Hope you make the right desision
I am at 156000 and still have original ball joints , and they seem to be in good shape. Now i did just replace my sway bar bushings they were pretty much gone.
