When I hooked up my Edge CTS, this weekend, I got a P0299 code, turbo underboost. From all that I have read, it sounds like the ebp sensor. Who is the best person, on this site to order from and does anyone have a picture showing this sensor? I'd like to get it ordered and try to replace myself, this weekend.
P0299 could be over/under boost, sensor, dirty or shot turbo or actuator also. When I had it the turbo had to be replaced. Was beyond cleaning according to the tech.
It could also be a cracked flex joint or leaking CAC boot but I'd clean the turbo, EBP tube, EGR valve, and MAP sensor tube before I spent $$$ on an EBP sensor.
I get this code once in a while. I clear it, it sometimes come back after 1000 miles or so, I do not worry too much about it, I guess it could be a glitch with an EGR sticking, a turbo sticking a bit, a Map sensors too sensible.
For the past two months I went threw the whole P0299 underboost issue. I spent good money after bad changing sensors, cleaning the EGR cooler and turbo. At the end of the day I replaced the turbocharger which is a good bet on what you'll be doing. I would say if you got the dough replace the EGR cooler w/a Bullet Proof ($350) and replace the Turbocharger w/a Garrett HP ($1400. Do not buy a rebuilt). Your going to have to do it sooner or later, may as well take it like a man!
Also, when I did the work, my 05 6.0 PSD runs like a brand new X. I could not be happier (at this point anyway).
you could Backprobe it with a DVM but then you would have to convert the volt reading to a pressure reading
<TABLE style="WIDTH: 654pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=872><COLGROUP><COL style="WIDTH: 654pt; mso-width-source: userset; mso-width-alt: 31890" width=872><TBODY><TR style="HEIGHT: 60pt" height=80><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: lime; WIDTH: 654pt; HEIGHT: 60pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 height=80 width=872 align=left>BTW -
Normal EBP signal reading should reflect atmospheric pressure with the key on/ engine off. Typically, this is 14.7 PSI/0.88-0.9 volts at sea level, decreasing one PSI/0.10 volt for every 2000 feet of elevation. It should be within 0.5 PSI of BARO and MAP sensor pressure signals.</TD></TR></TBODY></TABLE>
Theres a bunch of stuff in the spreed sheets do you have those?????
