RECON LED Cab Light Install with Pictures
#31
Old thread I know. How do the lights mount/remove? I have the FCC (what your callin recon) lights and I want to pull them off to investigate a cab water leak. Do the light bases just pull out? I can't tell from your pictures. Is there anything between the roof and light base, EG a gasket or sealant?
I have water coming in which drips out of the upper plastic screw access hole cover of the drivers side pull handle on the A pillar, then it drips onto my left knee.
TX
Steve
TX
Steve
#32
TX
Steve
TX
Steve
Side note: don't soak the sealant in the Alcohol when you clean up. Wet a paper towel with the alcohol and wipe it clean. Just as you would if chalking your bathroom.
#33
#34
#35
Put Masking tape on the truck's roof around the light base. This is on the painted area not on the rubber seal. Do this prior to removing each light assembly. Sealant has a way of making a big mess even if your really careful. After you have removed, cleaned, and sealed the light pull the tape up. 3M painters masking tape in 1/2" and 2" wide strips should do it. If you only want to buy one role get the 1/2" and put down enough pieces down overlapping them to put at least 2" of tape around the light. The Picture shows a tail light but it is the best I could find on google.
For a video of the removal here is a You tube one
TexasRebel
1999 to 2016 Super Duty
30
11-24-2010 09:19 AM
RockyMtnRanger
08-07-2007 02:05 PM
