Shudder/Shake
Old Jan 29, 2012 | 08:06 PM
davewave649's Avatar
davewave649
Shudder/Shake
So my truck has been developing a little bit of a shake. at around 40 mph and again at 70 mph the whole truck starts shaking sorta like its on a rough road. If i speed up or slow down some it goes away then if i return to that speed it comes back.
Any ideas as to whats causing this? Im hoping its not the drive shaft or the differential cuz i have no money...
Dave
Old Jan 29, 2012 | 08:27 PM
critterf1's Avatar
critterf1
Tire balance, U-joint.
Old Jan 29, 2012 | 08:53 PM
KO1960's Avatar
KO1960
I agree with Critter. Tire imbalance will act that way at certain speeds.
Kurt
Old Jan 29, 2012 | 08:59 PM
davewave649
Hmm i got new front tires over the summer. Ill take em back to americas tire and have them recheck them. How should i check the u-joints?
Dave
Old Jan 29, 2012 | 09:27 PM
1972RedNeck's Avatar
1972RedNeck
Check your tie rod ends.
Old Jan 29, 2012 | 10:49 PM
bunchoftrucks's Avatar
bunchoftrucks
to check the u-joints I block the front tires put the truck in neutral jack up the rear end . Then grab the drive shaft and see if there is any play up/down, sideways at each end of the driveshaft. If it moves replace the u-joints
Old Jan 29, 2012 | 10:57 PM
davewave649
Sweet thanks. Ill check the tie rods too. What would be the fastest way to check that?
Old Jan 30, 2012 | 01:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If you have a two piece driveshaft, there's a drive shaft center support that contains a sealed bearing, U shaped rubber support, misc brackets.
When the bearing begins to fail, a vibration begins that can radiate throughout the entire vehicle.
Old Jan 30, 2012 | 01:39 AM
davewave649
Thanks for the idea but it's a single piece
Old Jan 30, 2012 | 10:27 AM
huckdeuceman's Avatar
huckdeuceman
I had a tire that had a bubble on it, could hardly see it but could feel a hump/bump on it
check all tires and see if you can feel anything?
Old Jan 30, 2012 | 01:58 PM
garbz2's Avatar
garbz2
This is espically true if you loose the farrier nails some one in the past placed in the rubber to tighten it up in leiu or replacing it.........
Garbz
Old Feb 10, 2012 | 04:23 PM
davewave649
So last weekend i started looking for issues. U Joints are fine, same with the tie rods. Couldnt see any bubbles in any of the tires when i was down there. The driver side tire was rubbing on one of the arms for the steering so i adjusted the stops and will go get it rebalanced asap. There is some play in the steering box but it has been that way since ive owned the truck.
Any other possibilities?
Old Feb 10, 2012 | 07:24 PM
bunchoftrucks
At this point I'd get all the tires rebalanced. Another thought are you running bias ply or radial tires? If they are bias and it sits then sometimes they flat spot until they get warmed up..
hornychief
1997 - 2003 F150
Mar 5, 2014 11:56 AM
chrison600
Apr 20, 2013 09:30 AM
gabbagabbawill
Mar 3, 2013 04:21 PM
REDFORDFX4
2004 - 2008 F150
Aug 31, 2006 08:42 PM
mike1998
1997 - 2003 F150
Jun 18, 2004 12:44 PM
