302 block
Old Jan 29, 2012 | 03:37 PM
zombiefied 247's Avatar
zombiefied 247
302 block
is there any difference between a 1978 ford 302 block and a 5.0 302 block from like 86 and newer?????
Old Jan 29, 2012 | 03:42 PM
5pntslw's Avatar
5pntslw
There are slight differences but what are you trying to do? I can answer just about any question about it you have..
Old Jan 29, 2012 | 03:43 PM
BlueOvalRage's Avatar
BlueOvalRage
The early block will be a slightly thicker casting and will be heavier, but it's not really important unless you intend to make stupid amounts of horsepower. Dimensionally they are the same. The later block will also be machined for a 1-piece rear main seal where the earlier one will use a 2-piece. The 1-piece is preferred. The bigest difference is that the later block will probably have the taller lifter bores necessary for a roller camshaft. You can run a flat tappet cam in a late block with no problem, but it takes a later block if you want to run a roller cam with the factory roller components. I personally prefer the later blocks for everything I build.
Old Jan 29, 2012 | 03:47 PM
zombiefied 247
i am just wandering if headers from a newer mustang block would work on mine.my block came out of 78 lincoln
Old Jan 29, 2012 | 03:52 PM
5pntslw's Avatar
5pntslw
Yeah I don't think the exhaust flanges are different, all the ones I've messed with thru the years of building mustangs they were all the same
Old Jan 29, 2012 | 04:34 PM
zombiefied 247
thanks for the info
Old Jan 29, 2012 | 09:32 PM
52 Merc's Avatar
52 Merc
Unlike a flathead, the exhaust doesn't have any real relation to the engine block on a 302.
Old Jan 30, 2012 | 02:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The only Lincoln that came with a 302 prior to 1980 were 1977/79 Versailles that were also available with 351W's.
The Versailles was basically a rebadged Granada/Monarch with a 'toilet seat' decklid.
unleashed
Jul 17, 2007 11:06 PM
mla
Feb 12, 2005 11:33 AM
bron1967
Oct 22, 2004 12:40 AM
Robw_z
18
Mar 6, 2004 06:59 PM
