Posi question
Old Jan 29, 2012 | 02:38 PM
WVU's Avatar
WVU
Posi question
Hey all, just bought a used dana 60 LSD. Is there anyway to check the condition of the clutches while it sits here on the table?
Old Jan 29, 2012 | 05:24 PM
mark a.'s Avatar
mark a.
Not really, no way to tell just how good they are.
Old Jan 29, 2012 | 07:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Nope. The only test Dana recomends requires the diff be in the truck.
The service manual says make at least three figure eight turns, then jack up one wheel so it's completely off the ground. Bolt on the special adapter to the wheel (this tool allows the torque wrench to be centered on the wheel hub). Then take a torque wrench and turn the wheel. Ignore breakaway torque and look only at the torque required to continuously turn the wheel. Minimum torque 25 ft/lbs, max torque 200 ft/lbs.
If the reading is outside this range, it's time to tear it down and repair.
Old Jan 29, 2012 | 09:49 PM
WVU's Avatar
WVU
Okay thank you!
Old Feb 16, 2012 | 04:46 PM
WVU's Avatar
WVU
Bumping for a related question..
Hopefully going to get this limited slip in this weekend. I want to clean it up a bit since its been sitting on a shelf for a while. What materials would be good to use on it to get the grime off? brake cleaner maybe? elbow grease of course
Old Feb 16, 2012 | 04:47 PM
WVU's Avatar
WVU
Just a thought, maybe a dumb one, maybe not but what about a run through the dish washer?
Old Feb 16, 2012 | 06:23 PM
wasowski's Avatar
wasowski
dish washer = divorce
tried to clean up the bar b q grill in the dish washer ,just made a mess of the dishwasher
spray it with some purple power and pressure washer it
Old Feb 16, 2012 | 06:28 PM
Blue and White's Avatar
Blue and White
It depends on where the dirt is. If the internals (gears, bearings ect) are dusty, I would use an engine hoist to suspend it over a solvent wash tank and thoroughtly clean it with solvent and a soft brush. Then I would hit it with WD40 or similar for short term protection from rust. NO WATER. With all the nooks and crannies on a diferential, I would be real worried about trapped water and rust with water.
If the outside has baked and caked grime, which I bet it does, I would protect/mask the internals with heavy plastic first then use a wire brush and solvent. If it is really tough, paint stripper first will loosen it up.
Old Feb 16, 2012 | 06:40 PM
WVU's Avatar
WVU
Well i guess the dishwasher is out haha.
Would brake parts cleaner be out of the question?
I dont have a solvent tank or anything heavy duty thats why i was thinking that. What harm would come if i couldnt get all the nooks and crannies but instead just doused it with diff fluid, got in there all nice and deep like and threw it in the truck?
Old Feb 16, 2012 | 07:52 PM
J ballan's Avatar
J ballan
Brake clean works great for cleaning all sorts of parts but you will need a wire brush for the thick crap. Also use it in a well ventilated area, stuffs nasty!
Old Feb 16, 2012 | 07:57 PM
lostinfords's Avatar
lostinfords
make sure you add a posi additive w/ the install....good luck
trike1946
General Automotive Discussion
Feb 15, 2019 07:46 PM
bigb56
Apr 21, 2015 12:46 PM
Lariat#1
Garage & Workshop
Apr 27, 2008 09:18 PM
last5oh_302
2004 - 2008 F150
Jun 11, 2007 05:46 PM
blueford85
Feb 13, 2004 11:12 PM
