Sponsored by: Real Truck
Correct engine oil: E-350 van?
Old Jan 29, 2012 | 10:25 AM
scooterspal's Avatar
scooterspal
Hello to all.
Looking at purchasing a 1999 E-350 super duty extended passenger van and I'm trying to figure out the correct engine oil for it.
The one I'm looking at has the 6.8L V10 engine.
I will need to drive this home about 100 miles and since it has not been used for about a year I will have a local shop replace the oil and filter prior to my trip home.
I'd like to bring the correct oil along to get things off to a good start.
From what I've read there is some confusion (maybe it's me) on whether to use 5W30 of 5W20. Apparently Ford changed their spec at some point.
Can someone please give me the correct answer, which oil they recommend and the filter #, as well, for this specific vehicle?
Thanks for any help you can provide.
Old Jan 29, 2012 | 10:41 AM
n7bsn's Avatar
n7bsn
RTFM?
The manual for my 99 F250 V10 says 5w30.
The manual for my 2008 F350 V10 says 5w20.
I simply use a good grade and changed it every 6 months or so
Old Jan 29, 2012 | 11:00 AM
dkf's Avatar
dkf
The cap says 5w-30 that is what I would run. Ford switched over to 5w-20 sometime in the early 2000s on the gassers. My 04' specs 5w-20 and I have been running 5w-30 since the warrenty expired at 36k miles. The lighter oil is mainly due to emissions, mpg and standardization to reduce stock.
As for type of oil that is up to you Ford specs a semi synthetic which is what most dino oils are nowadays anyway. I run a name brand synthetic in mine. I would recommend sticking with the Fl-820S oil filter though. The best bang for the buck filter out there IMO and have the Ford spec silicone anti-drainback valve.
Old Jan 29, 2012 | 02:33 PM
scooterspal
Thanks.
I take your advice and stick with 5W30 and the Motorcraft FL-820S filter.
Much appreciated : )
Old Jan 29, 2012 | 07:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford changed the required oil on all gas engines except the 4.0L V6 to 5W-20. That's what's best, but 5W-30 is fine, too.
mikeismadness
Oil & Lubrication
Aug 16, 2012 03:12 PM
993/4ton
Modular V10 (6.8l)
Oct 14, 2006 11:45 PM
cajundaddy2
Modular V10 (6.8l)
40
Mar 3, 2006 03:03 PM
farm1966
Aug 17, 2005 07:32 PM
RKNRL
Modular V10 (6.8l)
36
Jul 20, 2005 12:03 PM
